rakeshtagotra Posted August 26, 2008 Share Posted August 26, 2008 I wanna know is there amy way to delete all the materials from the material editor or all the materials from the scene in one go. I am using 3dmax 2008. Thanking you all in anticipation. Link to comment Share on other sites More sharing options...
Brian Smith Posted August 26, 2008 Share Posted August 26, 2008 I wanna know is there amy way to delete all the materials from the material editor or all the materials from the scene in one go. I am using 3dmax 2008. Thanking you all in anticipation. to remove the materials in the ME, go to the Utilities menu in the ME and click Reset ME Slots. to remove the materials on the objects, go to the Utilities panel, click More and select UVW remove. this utility removes materials and mapping and returns the objects to display only their object color. Link to comment Share on other sites More sharing options...
Thablanch Posted August 26, 2008 Share Posted August 26, 2008 there is also a Blur script that does that. The Blur script package is kinda of a must, lots of nice goddies in there, that will save you tons of time. http://www.neilblevins.com/blurscripts/blurscripts.htm Link to comment Share on other sites More sharing options...
rakeshtagotra Posted August 26, 2008 Author Share Posted August 26, 2008 to remove the materials in the ME, go to the Utilities menu in the ME and click Reset ME Slots. to remove the materials on the objects, go to the Utilities panel, click More and select UVW remove. this utility removes materials and mapping and returns the objects to display only their object color. Thanks for helping me. but still i do have one problem. i haven't understood how to remove the materials on the objects.Pls explain in detail with reference image. Thanking you very very much. Link to comment Share on other sites More sharing options...
kippu Posted August 26, 2008 Share Posted August 26, 2008 select all objects and give it one standard grey material ? is that it? Link to comment Share on other sites More sharing options...
Brian Smith Posted August 26, 2008 Share Posted August 26, 2008 Thanks for helping me. but still i do have one problem. i haven't understood how to remove the materials on the objects.Pls explain in detail with reference image. Thanking you very very much. there's nothing more to explain...again go to the Utilities panel, click More and select UVW remove. what's not working? Link to comment Share on other sites More sharing options...
Tommy Burns Posted August 26, 2008 Share Posted August 26, 2008 What I do is select everything. Go into the material editor. then "get material", when this is open "drag" the "none" material onto the selection and chose apply to selection. Link to comment Share on other sites More sharing options...
rakeshtagotra Posted August 26, 2008 Author Share Posted August 26, 2008 I am very sorry but i haven't found any option like that. here here is snapshot of that thing. now pls tell me where i am wrong and what to do. Link to comment Share on other sites More sharing options...
Brian Smith Posted August 26, 2008 Share Posted August 26, 2008 I am very sorry but i haven't found any option like that. here here is snapshot of that thing. now pls tell me where i am wrong and what to do. the Utilities panel...in the Command Panel...not the ME Link to comment Share on other sites More sharing options...
rakeshtagotra Posted August 26, 2008 Author Share Posted August 26, 2008 (edited) Thanks sir thanks for helping me in such a nice way. But sir its still showing the maps which i have used in the scene..... in material editor when we click on standard options there is radio button named scene . what to do to clear all the history of material editor. Edited August 26, 2008 by rakeshtagotra Link to comment Share on other sites More sharing options...
LukeC Posted August 26, 2008 Share Posted August 26, 2008 If your wanting to strip the object of all materials - select the object and type into the listener window (little pink box, bottom left of the screen) $.material=undefined that'll clear them all together. I also could have misinterpreted the question given its late and I'm tired (and have been looking at max far too long for one day) Link to comment Share on other sites More sharing options...
Tommy Burns Posted August 26, 2008 Share Posted August 26, 2008 What I do is select everything. Go into the material editor. then "get material", when this is open "drag" the "none" material onto the selection and chose apply to selection. What is wrong with trying this way then if you can't follow Brians It's simple!!!! Link to comment Share on other sites More sharing options...
rakeshtagotra Posted August 26, 2008 Author Share Posted August 26, 2008 yes tommy u r very right. i have followed the brain's method that was very easy and good enough. i have already follow ur method also. but my last question is how to delete these files from material editor. plz help me in that. Link to comment Share on other sites More sharing options...
Brian Smith Posted August 26, 2008 Share Posted August 26, 2008 yes tommy u r very right. i have followed the brain's method that was very easy and good enough. i have already follow ur method also. but my last question is how to delete these files from material editor. plz help me in that. your image shows that you have not stripped the objects of their materials. i seriously dont know how to explain it any simpler. select an objectwithin the Command panel select the Utilities panelclick the More buttonselect UVW Removeclick the Materials button if you do this, you cannot possibly have the object contain a material, and if you do this to all objects you cannot possibly have any materials show up in your ME like you do. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 26, 2008 Share Posted August 26, 2008 actually I'll admit this went right over my head for a second till I realized which utilities panel Brian was talking about (then I slapped my forehead and said duh....) I don't go into the utilities panel that often other than to do a reset x-form now and then, so here it is clear as day.... Link to comment Share on other sites More sharing options...
Brian Smith Posted August 26, 2008 Share Posted August 26, 2008 (edited) actually I'll admit this went right over my head for a second till I realized which utilities panel Brian was talking about (then I slapped my forehead and said duh....) I don't go into the utilities panel that often other than to do a reset x-form now and then, so here it is clear as day.... doh! Edited August 26, 2008 by Brian Smith Link to comment Share on other sites More sharing options...
rakeshtagotra Posted August 27, 2008 Author Share Posted August 27, 2008 Thanks everyone for helping me especially the Brain for his kind attitude. My problem is solved. Thanking you all once again. Link to comment Share on other sites More sharing options...
