How do you change the time of day and location in Vray?
TomA
just put in a daylight system as you would have in 3ds max before you used vray and then in the modify panel change the sunlight type to VRaySun.
I can't seem to choose VraySun in the modify panel, only standard or IES.
Is this because i'm using Max version 8 and Vray 1.5 rather than more recent versions?
not too sure, only used vray since the latest release with max 2009
sounds silly but make sure you have vray selected as your render engine
if all else fails you could always put in the daylight system, turn sun and sky off, put in vray sun in same place and then link it to the daylight system
in other words create a parent child relationship between them so that when one moves, the other moves with it.
nothin complicated and not sure if it will work but worth a go, then you can control position of sun using daylight system controls
  • 2 months later...
one thing to be careful of when doing night to day animations, is the exposure settings, take a look at an exposure chart and you will see that different exposures are used for different times of day.
yes i noticed that, but i guess it is not very difficult to correct it ? i mean frame by frame technique works doing this ? i mean...rendering some frames and corecting exposures with autokey could do the trick..am i right?
