litleboy Posted August 28, 2008 Share Posted August 28, 2008 I need to import c4d to Lightwave. any idea? Link to comment Share on other sites More sharing options...
IC Posted August 28, 2008 Share Posted August 28, 2008 Export to 3ds, dxf or obj. What do you need to do? LW 9.5 has better options. Link to comment Share on other sites More sharing options...
litleboy Posted August 28, 2008 Author Share Posted August 28, 2008 its for a close friend, he needs to import a c4d file in to LW, I thought I could import in to max and export to a LW compatible file. Link to comment Share on other sites More sharing options...
3dworks Posted August 29, 2008 Share Posted August 29, 2008 its for a close friend, he needs to import a c4d file in to LW, I thought I could import in to max and export to a LW compatible file. just in case, there's this: http://www.firevector.com/firevector-products.html cheers markus Link to comment Share on other sites More sharing options...
GeneralCody Posted January 27, 2010 Share Posted January 27, 2010 Just use the free Autodesk FBX Converter, after saving your work in C4D, use it to translate into the format of choice for Lightwave, edit and save in LW, then run it through the converter once more, just to make sure it conforms, then import it to C4D again... Link to comment Share on other sites More sharing options...
