Wolf Posted June 14, 2002 Share Posted June 14, 2002 There are a few keys that i use almost everyday in max, and most of them are not even documented, so i thought id list a few of them: BACKSPACE when creating a line, and you misplace one, Hit the backspace to undo your last vertex. [ ] The bracket keys interactively zoom in and out when you are creating a line I Stands for Interactive Pan, lets you pan the screen when creating a line r(number) When you need to add or subtract a value in a typefield, just type r and the number you need, and it will add or subtract for instance... i have a wall thats extruded 1.385m high and you have to add .285 to it, just type r.285 in the field, and it will automatically calculate the result to subtract type r-.285 Anyone else got any shortcuts in max that theyd like to share? Link to comment Share on other sites More sharing options...
nisus Posted June 15, 2002 Share Posted June 15, 2002 Hi wolf, I like the 'r'-thing Here are a few other tips: ALT+A for align (use it a lot to model accurately) SHIFT+Z this gets you back to your previous viewport (after a zoom, or rotate in perspective mode) X to toggle the translation axis on/off Q to hide the modify/create panel SHIFT-I for the spacing tool and the most important one: RC (rightclick) on the spinners to get the value to zero!!! rgds nisus Link to comment Share on other sites More sharing options...
Erik Lund Posted June 19, 2002 Share Posted June 19, 2002 And yet the best time saver is a mouse that has a scroll wheel. With the scroll wheel you can zoom in/out, pan and rotate. Even when drawing splines! If you don't have one yet get one! You'll wonder how you ever got by without it. Link to comment Share on other sites More sharing options...
quizzy Posted June 20, 2002 Share Posted June 20, 2002 NO WAY!!! Its my biggest problem I have with MAX that you can't zoom and pan with the scroll button while drawing splines... How is this done??? TELL ME PLEASE!!!!!!!! (A little desperate...) Link to comment Share on other sites More sharing options...
furystylee Posted August 27, 2002 Share Posted August 27, 2002 The most addicting for me is the right-click undo. i try to use it in every program... Link to comment Share on other sites More sharing options...
bluebox Posted September 3, 2002 Share Posted September 3, 2002 As for drawing splines in MAX , there's onther handy thing - hold down shift while creating a spline and you turn on something like an ortho- mode. I'm using MAX 4 and the backspace thing (undo vert creation) didn't work for me, so I guess it's not a deaufalt setting. Link to comment Share on other sites More sharing options...
plastic Posted September 3, 2002 Share Posted September 3, 2002 Quote Originally posted by quizzy: NO WAY!!! Its my biggest problem I have with MAX that you can't zoom and pan with the scroll button while drawing splines... How is this done??? TELL ME PLEASE!!!!!!!! it's possible with the mouse wheel. simply roll it to zoom. panning is a bit tricky, you have to zoom to pan (since pressing the mouswheel will cancel spline creation) say you want to pan to the right, place the curser at the left side of the view and Zoom OUT, then place the cursor at the right side and zoom IN. the 'I' and '[' ']' keys are new to me, thats cool when using a tablet, with the mouse i prefer my method, its faster... [ September 03, 2002, 04:48 AM: Message edited by: Marc Lorenz ] Link to comment Share on other sites More sharing options...
Guest saturnfive Posted September 3, 2002 Share Posted September 3, 2002 Quizzy- As wolf said: for drawing splines, when you approach the screen edge, 'I' will pan for you, use [ and ] to zoom in / out and backspace to go back to the previous vertex. (I didn't know those, thanks wolf) If you're using straight line splines you can just draw any old rubbish with the correct no. of points, then convert to editable spline, go to vertex mode and just drag them where you want them. Link to comment Share on other sites More sharing options...
