Jet Posted July 31, 2003 Share Posted July 31, 2003 I started a radiosity Calc on an interior that I was doing, and I had the Initial Quality set to 90%. I noticed that as it got closer to 85% that it started going slower, and then it eventually started going backwards. It went all the way down to about 68% What does this mean, and Three hours have gone by. it is just a little 12 x 11 room. and the only light that is being used is a daylight,(skylight) with .5 multiplier What does this mean? And how do i get it to go all the way thru to the end. Jet Link to comment Share on other sites More sharing options...
Jennifer Posted July 31, 2003 Share Posted July 31, 2003 Hi, I've seen that happen before, and it eventually completed. Have you done calcs on this scene before, or was this the first time? Have you done other radiosity scenes, and if so, how does three hours compare time-wise? You can stop and restart the calculations, you don't have to wait for 90%. - Jenni Link to comment Share on other sites More sharing options...
Jet Posted August 1, 2003 Author Share Posted August 1, 2003 Ok I reduced the quality to 80% and it went thru. Weird,but it only too, 47 minutes Jet Link to comment Share on other sites More sharing options...
Hazdaz Posted August 2, 2003 Share Posted August 2, 2003 Maybe you discovered a way to go backwards in time?? :ngelaugh: Link to comment Share on other sites More sharing options...
