Vray sp2 - v-ray warning
alex18_ph
Hi does anyone know how to get rid of the vray waring "The file was created with an older version of the v-ray renderer. the dmc sampler noise thereshold parameter may need to be increased in order to get smililar resuslts..."? when using distributed rendering?
thanks in advance
  • 1 month later...
  • 2 weeks later...
Have the same problem. It worked nice until I tried rerender a old project (older version of vray). Now No project works as supposed to. I wonder why? Is there a temp file somewhere that have to be reseted? Any tip to why V-ray starts to confuse itself?
-K-
  • 1 year later...
Solution By M. Dave Buchhofer Is...WORKING ! GReat !
i put a script with his one simple line of code in each startup folder of my slaves computer/node and renders work fine now !
folder startup .script with one line :
setVRaySilentMode()
Thanks man.
no more 'The file was created with an older version of the v-ray renderer. the dmc sampler noise thereshold parameter may need to be increased...'
even if this post is older and use of THIS vray maybe old too...i write this in case someone could need it !
