chortik Posted September 2, 2008 Share Posted September 2, 2008 Hi, I may seem like a fool, but... Can I render a camera walk through animation in the Vray Frame Buffer? I ask because when rendering still images and useing the exposure and color curves correction utility for a better image quality, so I would like to achieve same results in animations. Thanks to all Link to comment Share on other sites More sharing options...
BrianKitts Posted September 2, 2008 Share Posted September 2, 2008 yes you can, but it would be better to apply those adjustments in post using your animation editor, rather than burning the correction into the animation. Most video editors (Premiere, Aftereffects, etc) have adjustments for exposure and a curves editor. Link to comment Share on other sites More sharing options...
chortik Posted September 2, 2008 Author Share Posted September 2, 2008 Hi, If you do not mind, please enlighten me and give me a hint about how I could render my sequence through VFB although its not very common C. Link to comment Share on other sites More sharing options...
BrianKitts Posted September 2, 2008 Share Posted September 2, 2008 Hi, If you do not mind, please enlighten me and give me a hint about how I could render my sequence through VFB although its not very common C. read the manual on enabling the frame buffer and you've got it. as long as your frame buffer corrections are applied when you send the animation to render through backburner, it will apply those corrections to the final render. what makes you think its not common??..... I render everything through the Vray frame buffer. Link to comment Share on other sites More sharing options...
chortik Posted September 2, 2008 Author Share Posted September 2, 2008 Hi, My goal here is to make a small animation like 10 frames with one camera and simple light settings. In every frame I can adjust my camera position and after that I render whole sequence so that every frame will be saved separately to jpg and they have the same gamma curves etc. to each frame. I read all the manuals I could, but I did not find anything about sequence rendering. If you can send me a link or something I would appreciate it really!!! Regards, C. Link to comment Share on other sites More sharing options...
