GUI for a macro-script, help
Justin Hunt
Just a quick one,
I have developed a max script to tweak RPC materials. Not knowing much about scripting I used the Macro-recorder. It does the job but I would like to incorporate it into a GUI and have it affect all selected RPC's. At the moment I have to manually load each rpc material one at a time.
Would anyone be willing to help me finish this off.
Once its completed I will share it for all to use.
Thanks
Great thanks
here's the text
meditMaterials[1].material1.shaderType = 4
meditMaterials[1].material1.adTextureLock = on
meditMaterials[1].material1.diffuseLevelMap = Ambient_Reflective_Occlusion__3dsmax ()
meditMaterials[1].material1[#Maps][#Diffuse_Level__Ambient_Reflective_Occlusion__3dsmax____Ambient_Reflective_Occlusion__3dsmax].max_distance = 1000
meditMaterials[1].material1[#Maps][#Diffuse_Level__Ambient_Reflective_Occlusion__3dsmax____Ambient_Reflective_Occlusion__3dsmax].bright = color 179 179 179 255
meditMaterials[1].material1.selfIllumAmount = 0
It would be great if there was a way to specify the Ambient Occlusion Max distance and bright colour. First things first the ability to apply to selection
Thanks
jhv
heres the real basics.. just to make it work on a selection instead of the material editor
for rpc in selection do
rpc.material.shaderType = 4
rpc.material.adTextureLock = on
rpc.material.diffuseLevelMap = Ambient_Reflective_Occlusion__3dsmax ()
rpc.material.diffuseLevelMap.max_distance = 1000
rpc.material.diffuseLevelMap.bright = color 179 179 179 255
rpc.material.selfIllumAmount = 0
no error checking at all, but should be it, unless i spelled something wrong ;) will give it a go in a bit.
I just installed the plugin but it doesn't come with any test RPC's and the demo ones on archvision.com are not working anymore... Do you happen to have any of the demo ones?
I bought a couple years back some people from them but I have no idea where I have them...
You were right, it was not going down to the material so here is the adjusted code:
rpc.material.materialList[1].shaderType = 4
rpc.material.materialList[1].adTextureLock = on
rpc.material.materialList[1].diffuseLevelMap = Ambient_Reflective_Occlusion_3dsmax()
rpc.material.materialList[1].diffuseLevelMap.max_distance = 1000
rpc.material.materialList[1].diffuseLevelMap.bright = color 179 179 179 255
rpc.material.materialList[1].selfIllumAmount = 0
Many thanks, I had to tweak the ambient occlusion line to get it to work.
Its workg great so for all those who would like to try it I have uploaed the script.
In its basic form it makes sure that the self-illumination is set to 0. For some RPC's even if it is set to 0 in the Mass Edit the material itself still has self illumination set to 55.
By adding AO, it helps to tone down the over bright apperance when using final gather.
Many thanks to anton for compiling my rather messy script, I owe you a beer.
cheers
jhv
Big thanks to Dave as well.
RPC's do suck, but with a little trickery they can look ok, not great but ok.
Personally I think the parking lot car are the only real reason for keeping them in our workflow, especially so as large scale shopping centres are our main stay.
Thanks once again to everyone who helped
jhv
