Trouble Rendering Fire
Michael J. Brown
SNAP! I got it to work!
At least, it'w working in an isolated scene - all by itself. I'll see what happens once I merge it into the scene where I couldn't get it to work before (with Daylight System active). I'm thinking that perhaps the MR Sky as an Environment Map might be what caused the fire effect not to work everytime I tried it before. If so, I'll just turn it off and go from there.
  Brian Bradley said:
Hi Michael,
With a daylight system in the scene and exposure set up for
it you will NOT be able to see the effect of your fire! Just
as you wouldn't see any illumintion from a small hand torch if
you shone its beam onto a patch of Bright sunlight!!
regards
Bri
The fire is in a fireplace within a room. The nearest window is about 25' away and buffered by a wall. No direct light is entering the scene. In fact, very little (if any) indirect light is entering this particular scene. therefore I could elliminate the daylight system without any impact on my scene. It was being used primarily for the room with the window that this space in adjoining.
Got it! It was the Photographic E.C. preventing the fire effect from rendering.
This really throws a monkey wrench into things for me. I've been rendering sequences for an animation for the past two weeks - with Photographic E.C. And now as I'm about to round out the production work with my two sequences of the lounge (with fireplace), I discover that Photographic E.C. won't let me do fire. So now I've got to either try and massage a lighting solution in Automatic E.C that blends flawlessly with the P.E.C. solution, or just forget about the fire in the fireplace all together.
The post-production option of After Effects'ing' in some fire later is out because I niether own or know how to use After Effects.
Well...I really need that fire to help sell these two sequences. So I guess it's back down to the 'lab' to craft an Automatic E.C. solution commensurate to the Photographic one - YEAH RIGHT! Good luck, self.
