smr_VIZ Posted September 8, 2008 Share Posted September 8, 2008 Can anyone tell me if I can use standard camera to create the depth of filed effects for a rendering? I am rendering a scene with the camera 60 meters high above the ground. So there is alot of far side ground could be rendered. I want them to be faded away. Is the depth of field the right way to achive what I want? Thanks, Link to comment Share on other sites More sharing options...
Nic H Posted September 8, 2008 Share Posted September 8, 2008 depth of field or distance fog will work - beware if you use dof be careful you dont end up with a miniature scale model style image like this! id do a zdepth pass and use it in photoshop - filter - blur - lens blur, so you have some control over it. will render alot quicker as well. you can do a quick zdepth using a falloff map set to distance blend (with you values in the close far bit) in the vray material override or as an Extratex render element. Link to comment Share on other sites More sharing options...
