rikou Posted March 1, 2004 Share Posted March 1, 2004 Hi, I've a problem with max 6 (SP1 installed)... When I want to merge something, Max 6 throws me ! Anyway, does anybody met this problem ? THX Link to comment Share on other sites More sharing options...
Jennifer Posted March 8, 2004 Share Posted March 8, 2004 Hi, Does the merged file open fine all by itself? Are there any plugins that may be referenced in the merged file that do not exist in the instance of max you are using? Try merging objects one at a time to try and isolate the problem object. If you can open the file fine by itself, then try converting any objects with complex stack operations (boolean, meshsmooth, etc) into a base object, like Editable Mesh or Poly. Jenni Link to comment Share on other sites More sharing options...
