femmyextra Posted September 11, 2008 Share Posted September 11, 2008 Im new to Vray and I have an 8gb Ram running on Sp64. I noticed that my renders are slow and not impressive. Pls is there any workway around setting Vray to take adavantage of the Ram and render faster??......Pls Help Link to comment Share on other sites More sharing options...
WAcky Posted September 11, 2008 Share Posted September 11, 2008 You need to post more settings. What OS are you using. It could be that you are only running a 32-bit OS and you need to either upgrade or do that 2gb switch trick. Welcome to the world of Vray. Balancing speed with quality. You should probably go to the chaos group forums or do some tutorials so you can learn how and what to adjust to get better speeds without sacrificing too much quality. Link to comment Share on other sites More sharing options...
