Attaching an image???
robert taylor
from my notes:
adding a background photo to a rendered scene
01) start with .TGA file with Alpha Channel from a rendered scene in Max
02) make a copy of the original layer and hide the original layer
03) open the background image - adjust the size to fit the rendered image
04) make a new (empty) layer in the rendered image - move it BELOW the rendered image
05) click back on the rendered image layer
06) [ignore this blank line]
07) click on Channels tab
08) make all layers visible
09) click on alpha channel
10) click Load Channel as Selection
11) Click on Layers Tab
12) Selection -> Invert
13) Edit -> cut, or just press the DEL key
14) marquee and select the background image, copy, then past it into rendered image in a new (empty) layer
15) The background will now be visible through the windows
Hope it helps. Edited by SandmanNinja
Yay! My 1100th post!
