e_cbautista Posted September 13, 2008 Share Posted September 13, 2008 hi everyone! has anybody tried using standard matl with vray renderer? is there any significant improvement in speed? i need to do a short cam fly through of an interior, or should just i settle using scanline when deadline is tight? btw, im using 64 bit os, intel quad with 8gb ram and ati 3870x2. this forum is a lot of help and i thank you all! Link to comment Share on other sites More sharing options...
tayrona Posted September 14, 2008 Share Posted September 14, 2008 You can use standard mats with vray... obviously vray mats work better. some glossy effects that are time consuming with vray mats, could be replaced with standard mats if time saving is your priority, in animations for example I use standard mats with glossys in low detail geometry that is not in first plane in the visualization. Link to comment Share on other sites More sharing options...
e_cbautista Posted September 15, 2008 Author Share Posted September 15, 2008 thanks tayrona.. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted September 15, 2008 Share Posted September 15, 2008 As a matter of fact, you don't have to use standard mats at all. If you want the fake glossy thing, just turn off the Trace Reflections option in the VRay Mat. Remember, VRay mats are more advanced and optimized than Standard. Link to comment Share on other sites More sharing options...
e_cbautista Posted September 18, 2008 Author Share Posted September 18, 2008 thanks rick for the insight. Link to comment Share on other sites More sharing options...
Joseph Petrino Posted September 19, 2008 Share Posted September 19, 2008 "Lightcache" will give you strange results with standard mats. Link to comment Share on other sites More sharing options...
e_cbautista Posted September 21, 2008 Author Share Posted September 21, 2008 joseph, now that you mention it- thanks! (i use lc most of the time) guess ill have to settle with vray matl then. Link to comment Share on other sites More sharing options...
James S Posted September 24, 2008 Share Posted September 24, 2008 sometime standard materials prevent creating proxies - I have found this with Onyx trees (v1.5 sp1) Link to comment Share on other sites More sharing options...
