DirectX 10 in Max?
Macer
Is anyone that has a new-ish card (DirectX 10+) using the DirectX 10 driver in Max?
If you select DirectX (instead of Open GL) it usually defaults to the DirectX 9 driver (its under Preferences> Viewports> Display Drivers).
I was wondering if anyone had tried running Max using directX 10,? If so, how does it compare to DirectX 9? Does everything display correctly on your screen? do you get the same display rate or fps?
I have a GTX9800 on one pc but with the DirectX 10 driver some things (mainly the view cube thingys and some menu buttons) don't display the same as they do with the DirectX 9 driver.
Just curious more than anything.....
