navnow Posted September 17, 2008 Share Posted September 17, 2008 hi all, I'm working on a Walkthrough, and as u can see on the attached image, the walls and ceiling are very grainy. Can anyone tell me how to remove the grains on the walls/ceiling. I have attached the render setting too. Thanks in advance naveen Link to comment Share on other sites More sharing options...
kippu Posted September 17, 2008 Share Posted September 17, 2008 ur noise threshold at 0.05 is not adequate ..go lower i think Link to comment Share on other sites More sharing options...
chadw Posted September 17, 2008 Share Posted September 17, 2008 In your Adaptive Sampling you are using a min and max of 1 and 2, and a color threshold of 0.1. Start adjusting those numbers. For instance try undersampling with you min..... say -2 and over sample with your max.... maybe 3. Then adjust your color threshold to .05 or as low as .005. You are going to notice a spike in your render times but this should clean that up for you. Good luck. Link to comment Share on other sites More sharing options...
navnow Posted September 20, 2008 Author Share Posted September 20, 2008 thank u maria and chad for ur reply. when i reduce the color threshold value its to .01 its removing the grains but as said.. even the rendering time is going upto 1hr per frame. thanks again Link to comment Share on other sites More sharing options...
chadw Posted September 20, 2008 Share Posted September 20, 2008 What did you set you min and max at? Is this for an animation or a still image? Link to comment Share on other sites More sharing options...
chadw Posted September 20, 2008 Share Posted September 20, 2008 Also..... do I see a 3000 in you light cache? If that is the case you need to bring that to somewhere around 800. Link to comment Share on other sites More sharing options...
Tommy8 Posted September 20, 2008 Share Posted September 20, 2008 if you have vray light in your scene , you should check on the store wit irradiance map. Link to comment Share on other sites More sharing options...
navnow Posted September 22, 2008 Author Share Posted September 22, 2008 hi chad and tomer... > min and max values were not changed... (min -1 and max 2) > this is for animation (interior walkthrough). > i will cut the Light cache value to 800 and test. > i'm using some vray lights but most are default photometric lights. So should i still use the "store with irradiance map". but can u pls tell what "store with irradiance map" do. i mean the function of "store with irradiance map". thanks guys.. Link to comment Share on other sites More sharing options...
