UTI Posted September 19, 2008 Share Posted September 19, 2008 hi everyone ,,, i was just wondering if 32 bitt applications work on 64 because iam upgrading from xp32 to xp64 so do i need to upgrade all of my software as well? Link to comment Share on other sites More sharing options...
Macer Posted September 19, 2008 Share Posted September 19, 2008 Yes most 32 bit apps work on 64 bit OS. The only thing that I've come accorss that wouldn't work was antivirus - I had to get a 64 bit version. All of my other software works just fine. Link to comment Share on other sites More sharing options...
STRAT Posted September 19, 2008 Share Posted September 19, 2008 the only app i cant get to work are earlier versions autocad. (ie, acad2004) Link to comment Share on other sites More sharing options...
Jim Mann Posted September 19, 2008 Share Posted September 19, 2008 I don't recall having any problems with programmes in the past two and a half years using XP64 but drivers aren't as easy to get and you may find some web add-ons aren't compatible. I have ended up having to buy a newer modem and printer. I haven't been able to find drivers that will let me view Blu-ray, though I can create Blu-ray disks. Antivirus was a problem at first but have been using Avast antivirus since spring 2006 and that has done the job well. Aside from those minor limitations, XP64 has been great...and I use "great" in its most non-technical sense as in, it hasn't gone wrong and everything seems to run fast and smooth. Jim Link to comment Share on other sites More sharing options...
quizzy Posted September 19, 2008 Share Posted September 19, 2008 yes, well there is one major flaw though... Apple's Quicktime... you cant create quicktimes out of 64bit programs. you can create them using 32bit programs running on xp64 though. so for instance, if you would use .mov as a bitmap in your 32bit 3dsmax and render in 32 bit (on xp64) everything is fine. But if you need to render that scene later on xp64 cause the memory overhead of the scene is 64bit-demanding.. then you'll get a nice all black or diffuse colored quicktime. And thats not really funny. Why did adsk even allow us to select .mov in max 64bit, since they should clearly know this issue. Link to comment Share on other sites More sharing options...
Antisthenes Posted September 19, 2008 Share Posted September 19, 2008 even with QuickTime alternative ? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 19, 2008 Share Posted September 19, 2008 on a side note, 32 bit applications can not access more than 4 gigs of ram. more ram is the main reason to go 64. Link to comment Share on other sites More sharing options...
Matt McDonald Posted September 19, 2008 Share Posted September 19, 2008 I have ended up having to buy a newer modem and printer. Modem? Really? What's a modem? Link to comment Share on other sites More sharing options...
Antisthenes Posted September 19, 2008 Share Posted September 19, 2008 hey now! there is still use for a modem, to route your land line threw to record phone calls and have multi level answering machine on your PC, with communicate pro Link to comment Share on other sites More sharing options...
UTI Posted September 20, 2008 Author Share Posted September 20, 2008 thanks guys......that was more than enough for me cg architect ppl ..u r the best:cool: Link to comment Share on other sites More sharing options...
