autocad to maya
umare
Hello umare
Till now no Good Format for Translating...you sould use Autodesk Direct Connect . to Connect DWG Files t maya......Maya will import the DWG as A Bunch of NURBS Surfaces...No Textures and Materials....This is the worst thing if you plan to Make an ArchViz with in maya....you have to Remodel in maya....will be much better.
So If you need to Visualise an AutoCAD or Revit Project...MAX is Recomended!
Cheers
/Tai
I find that using sketchup as a bridge between autocad / revit to maya gives me the best results so far. DWG to sketchup, then FBX to maya will convert much cleaner geometry. Plus any blocks will be converted to components in sketchup which will be converted to instance copies in maya.
If you don't have sketchup you can always use the old 3ds to maya with the bonus tools 3ds import but i find it takes a lot more clean up that the latter method.
Blender http://www.blender.org/ is a great program for bridging between CAD and Maya as well... and it is completely free. Same workflow as Karlfucious mentioned CAD DXF > Blender FBX or OBJ > Maya. It is also good for the .3ds and .max imports.
I can't really comment on how well blender translates the files over since I've never used it but Sketchup converts over really clean geometry. Instead of importing a bunch of garbled triangles it tries to keep planar faces as ngons where possible. The only places it triangulates the mesh is where holes occur. That makes cleanup a much easier process and saves a lot of time. Also, all the face normals are in the correct direction.
Another plus of using the sketch up method as mentioned before is the fact that blocks/families convert to instance copies in Maya. So If you need to further detail a window you can model on one and the changes will carry over to each identical window.
With all that said there is no perfect translation. Sketch up is just the best I've found so far. Not only that Sketchup is a very handy little tool that I find invaluable to my pipeline.
Thanks for the info Karl. Tri's and normals are an issue. You can achieve similar results with Blender, though it isn't as simple as one or two clicks. Might just have to look into SketchUp.
995? naaa free for 25 saves or 140 for commercial licenses for students
Blender - free for unlimited saves, forever, for everyone...
  • 3 weeks later...
Hi everyone!thanks for welcoming me here,i really appreciate it.I'm an BS.Architecture grad.,and im working with autodesk cad for arch'l.plans,then rendering perspectives in 3ds max.,and finalizing in photoshop....but im planning to jump on maya for renderings..but the problem is,i havent mastered yet the cad on maya,max on maya..i hope can solve it....:)
  • 4 weeks later...
