max.m Posted September 24, 2008 Share Posted September 24, 2008 (edited) hi, i have a view questions to optimise my viewport performance i have a dell t7400 with a quadro fx4600. since a view days i use the direct3d driver. i saw that there are many adjustments possible - are some of the usefull or should i let them on default? mousescroll: can i define that the adaptive degredation also works when i zoom with mousescroll, and where can i adjust the degree of zooming by turning the mousewheel one notch?(the mouse properties in the control panel do not seem to influence it) Edited September 24, 2008 by max.m Link to comment Share on other sites More sharing options...
max.m Posted September 24, 2008 Author Share Posted September 24, 2008 discovered the possibility to define the wheel zoom increment in preference settings/viewports/mouse control Link to comment Share on other sites More sharing options...
mattclinch Posted September 24, 2008 Share Posted September 24, 2008 if you are using a quadro card, you may want to check out the nVidia MAXtreme drivers. Link to comment Share on other sites More sharing options...
max.m Posted September 24, 2008 Author Share Posted September 24, 2008 as i have a dell workstation i downloaded the latest drivers for the graphic card from their homepage. i was told only to use their drivers by dell when i purchased. how can i find out if the installed driver is a maxtreme driver or another one? Link to comment Share on other sites More sharing options...
mattclinch Posted September 24, 2008 Share Posted September 24, 2008 MAXtreme drivers are special D3D drivers by nVidia for use with Max. http://www.nvidia.com/object/maxtreme_archive.html Link to comment Share on other sites More sharing options...
max.m Posted September 24, 2008 Author Share Posted September 24, 2008 (edited) called dell again, they told me that the drivers from their homepage are not maxtreme drivers, so i will try them. thanks for the advices mattclinch. what`s left is the question if i can define that zoom with mousscroll also uses adaptive degradation, is this possible? Edited September 24, 2008 by max.m Link to comment Share on other sites More sharing options...
