uvw map problem
Guest xgr3d
hello.
when i mapping an object with uvw-map
and then collapse the object, if i will
move vertex or polygon the uvw will destroyed.
how can i move a vertex without destroying the
uvw mapping
thank's
xgr3d@yahoo.com
don't collapse the modifier stack as long as you want to change the mesh topology.
collapsing it will 'burn' the uvw map onto the object, it wont auto-update itself anymore. like any other collapsed modifier.
[ December 16, 2002, 05:49 PM: Message edited by: plastic ]
  • 1 month later...
Yeah, if you want to edit the mesh with the correct mapping, you have to let UVW applied. If you collapse, it will let the setting as is and will just be deleted. Make sure you apply all your modifications first and then collapse the layers.
