A.Mitov Posted September 27, 2008 Share Posted September 27, 2008 I'm thinking of buying some PCs for network rendering. The quesiton is do I need more than 4 gigabytes of RAM? They're gonna be used only as a render farm. Link to comment Share on other sites More sharing options...
SandmanNinja Posted September 27, 2008 Share Posted September 27, 2008 to use more than 4 gigs of ram would require a 64-bit OS. I think RAM is pretty affordable now-a-days, and having 8 gigs can make rendering easier and perhaps quicker (big scenes). Link to comment Share on other sites More sharing options...
Tay othman Posted September 27, 2008 Share Posted September 27, 2008 I'm Using a RenderBoxx it has a 16 gigz of ram for each node......In many Heavy Scenes I've Used about 12 GB of Ram at Rendering time (Especially in cityscapes). So I Recommend 16 GB of Ram coz 8 some time not enough Link to comment Share on other sites More sharing options...
AJLynn Posted September 27, 2008 Share Posted September 27, 2008 That's crazy! Unless your work is really detailed, if you're overrunning 8GB you've got a problem. Link to comment Share on other sites More sharing options...
SandmanNinja Posted September 27, 2008 Share Posted September 27, 2008 The only time I've 'run out' of the 8-gigs of RAM is when I had a lighting problem and Max got confused. User error. Link to comment Share on other sites More sharing options...
Lhanh29 Posted September 27, 2008 Share Posted September 27, 2008 i think 8Gb it could be Ok. i have been work with big project with a lot of trees proxies with too much detail.Some time it is "run out". I have never used 12, 16gb .. but i agree Toxic.box. Link to comment Share on other sites More sharing options...
Tay othman Posted September 27, 2008 Share Posted September 27, 2008 Once you have a Dynamics (Particles and Fluids) Smoke Dust ....etc....16 GB is ok... But For Archviz...I Think 8 is Fine. Link to comment Share on other sites More sharing options...
FlyinHawaiian Posted September 28, 2008 Share Posted September 28, 2008 I'm Using a RenderBoxx it has a 16 gigz of ram for each node......In many Heavy Scenes I've Used about 12 GB of Ram at Rendering time (Especially in cityscapes). So I Recommend 16 GB of Ram coz 8 some time not enough I've very rarely topped out my box (8gbs) though, with particles, and a lot of trees, I could see this happening. I'm really curious though, to see what sort of scenes you've worked on that have topped 12gbs. Are you able to post any images/frame grabs? Link to comment Share on other sites More sharing options...
Tay othman Posted September 28, 2008 Share Posted September 28, 2008 Hello Joel... My Scene is a Room with 12 characters (Children) With Cloth and hair (I Work in an Animation company - and our project is a Film not an Archviz ) and there is no Render proxies coz we work on maya 2008 / Mentalray. I Hope if I Can Grab Some images to Post them here.... Link to comment Share on other sites More sharing options...
FlyinHawaiian Posted September 28, 2008 Share Posted September 28, 2008 12 characters (Children) With Cloth and hair Makes sense. I guess that would put it over the edge. And all in the same pass? I have no idea how they are interacting or what's involved, but at least in archvis, I find that if I need to use more than 4gb, the frames generally take forever and it's worth it to break stuff out into seperate passes. (This way, if just a part of it needs changing, you can render just that pass.) I'd especially assume that this would be true when calcing hair. Seems like a pretty finicky thing, and short of pro films, most of the 3d hair I've seen has been less than perfect (meaning it could have benefited from a little more tweaking by the artist and therefore, another pass). Can't imagine 12 people with cloth and hair all in the same scene! If it looks good, I'll have to give you some serious props. (Now I'm extra curious to see what you're working on.) Link to comment Share on other sites More sharing options...
