Unwanted transparency!
DiegoFlores
Hello everyone!
I have this problem that suddenly started to happen.
Im trying to render opaque glass for an exterior facade with a vrayMtl.
The reflect parameter is set to gray, but the refract is set to black to suppousedly make it like a mirror.
Im not using any opacity maps either.
But everytime i render, it makes just this material a little transparent and it seems to be fixed if i disable reflections turning it to black.
It makes no sense and i have also noticed that its not a true material transparency(if i put something behind it would also make it transparent all the way to the background image).
I am wondering if there is a setting that might be doing this, i have allready tried starting over with the scene and materials.
[ATTACH]29212[/ATTACH]
i think it is not transparency, but reflections - change background when you render / render it with alpha - *.tga, *.png/ and then add background in PS
if you add background just like pics with screen mapping what is in background same pics is in foreground
- spherical maps with spherical mapping are rendering ok on reflected materials
Edited by martincg
you mean this supoused transparency is the refection of the forefront?
i tried renderng without an enviromental map but te color of the background still affects the image like it was transparent, or maybe is still refllecting it like you said.
I didnt seem to have this problem before.
by spherical maps, you mean HDRI maps?
i dont have one of those. I was actually planning to take pictures of the trees in front of the glass to use them as difusse textures, layered on top of the glass color.
i will try adding the background in Photoshop but still this reflection thing is not very clear to me.
