nelpiper Posted September 29, 2008 Share Posted September 29, 2008 Hi guys. I'm new to autocad. I'm in the UK and here we use mm rather than inches. The problem I've got a dwg from a client that is using inches as the default unit. So, whenever I try to use the DIST command, it returns the measurement in inches. How do I change the units so that when I use the DIST command, it shows the measurement in mm? Thanks. Link to comment Share on other sites More sharing options...
Lester_Masterson Posted September 29, 2008 Share Posted September 29, 2008 1 of 2 things to try. 1. Check the default units "ddunits" and see if it is set to Architectural. If so, switch it back to decimal 2. If this doesn't help, you will have to do it the hard way. Scale the entire drawing by a factor of 25.4 ( 1inch=25.4mm ) Hope this helps. Link to comment Share on other sites More sharing options...
BobM Posted September 29, 2008 Share Posted September 29, 2008 You will have to set the units to Decimal mm and the Precision to 0 decimal places. Then scale the whole drawing by 25.4 you should be OK then Link to comment Share on other sites More sharing options...
nelpiper Posted September 30, 2008 Author Share Posted September 30, 2008 Thanks guys. It worked. Thank you very much. Link to comment Share on other sites More sharing options...
