chainlink fence
chrisclocher
>>Does anyone know how to make a relatively low quality chainlink, I just need to see through it, from about 100' away.
Chris,
Use the Bricks map set to a square layout with Stack Bond in the Opacity slot and apply it to a flat plane or extruded line. Rotate the map itself or a UVW Map Gizmo 45 degrees.
Make the Brick color black and the Mortar white.
You might also need to copy the map into the Glossiness slot so the "holes" in the fence don't have Specular highlights.
Ted
Ted
