Mental Ray Problem...please Help Me!!!
art.chitect
The screen shots are too small - I can't read the settings.
You have 3 gigs of ram and a 32-bit OS. It might be having to hit the hard drive for more virtual RAM. Hard drives are a lot slower than ram chips.
Another thing could be the material at that particular location. A combination of light and materials might be making the render engine get really confused.
I cannot see your settings, but have you tried lowering the AntiAlias and/or Final Gather settings to see if it chugs past that point?
I had this happen to me once and I nudged the camera to the left slightly and it rendered fine. My issue was a really bright reflection on a material with a lot of samples.
Thx sanman, but i didn't touch the antialias setting
I already post another screen shot, would you take a look please?
Whai is it antialias,and what for?
thx
http://en.wikipedia.org/wiki/Antialias
has some visual examples
Basically, AntiAliasing helps with details.
From my notes:
Anti-alias and Oversampling
* Renderer tab
* the antialias filter is here (Filter type)
* oversampling is the min/max
* min:4 and max:16 is a high quality setting - gets rid of aliasing
* min:4 and max:64 - very high quality setting
* Tip From Justin Hunt
90% of the time I use Min: 1 Max: 16
if there is a lot of fine detail, moire patterns or detail "melting" into each other then I do 4, 16.
For testing I start at 1/4 , 4. If I ahve time in animations then it 4 ,16 (more if needed)
You can also drop the spatual contrast so that the max samples start sooner.
