Noise Posted October 2, 2008 Share Posted October 2, 2008 Hi Does anyone have a tried and tested method for modeling kerbs so that there is control over the mapping of kerb stones in such a way that they curve around bends ? We have a couple of methods which use the loft tool and the sweep modifier but neither are perfect - if the sweep modifier had the Length Repeat option which the Loft tool has - all would be grand but, it doesn't. thanks N Link to comment Share on other sites More sharing options...
Noise Posted October 2, 2008 Author Share Posted October 2, 2008 I have just worked out a solution; Use the sweep modifier and use real world mapping then in the bitmap tiling parameters - adjust this to get the desired tiling of the map, sorted ! Link to comment Share on other sites More sharing options...
Tay othman Posted October 3, 2008 Share Posted October 3, 2008 in Max 2009 if you had modeled with out sweep modifier......you can just use a spline mapping to map your objects along the Kerbs Link to comment Share on other sites More sharing options...
