kinkabobba Posted October 2, 2008 Share Posted October 2, 2008 Hello, So I'm trying to show a landscaping shift in an urban circus through animation. I started with a circle and used the sweep modifier to make the 'hilly' shape the circus currently has. I'd like to show the shape morphing into a level shape, essentially a tube. Is there any way to animate the section of a sweep modifier? If not, does anyone have any other ideas how this might be done? Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted October 2, 2008 Share Posted October 2, 2008 melt maybe? Link to comment Share on other sites More sharing options...
Chad Warner Posted October 2, 2008 Share Posted October 2, 2008 Try using loft (under compound objects) instead of sweep. There are many more modifiers that you can do with it. Link to comment Share on other sites More sharing options...
Gander0 Posted October 3, 2008 Share Posted October 3, 2008 You can animate the section of a sweep modifier. Or if your just going from undulating to flat you could always just animate the scaling Z axis Link to comment Share on other sites More sharing options...
