ishpalsingh Posted February 12, 2004 Share Posted February 12, 2004 after going thru smoke's editable poly tutorials i thought i should start modelling in max5. so i made three splines in autocad & imported it to max 5.in max i extruded the splines then attached them at there resp levels& welded there vertices.when i tried to cap close the holes.max made it look weird.so i manually made the holes & extruded them with 0 thickness & then i attached them to those extruded splines & welded there vertices. then i extruded the polygons in front view but when i tried to give thickness to these walls by cap closing the holes with the help of border subject max again is messing them up tell me wat i m doing wrong. or tell me a better method to do this Link to comment Share on other sites More sharing options...
Ted Boardman Posted February 13, 2004 Share Posted February 13, 2004 >>by cap closing the holes with the help of border subject max again is messing them up It looks to be a Normals issue, Ishpal. Try assigning a material with the 2-Sided option checked and see if that fixes it. Ted Link to comment Share on other sites More sharing options...
ishpalsingh Posted February 13, 2004 Author Share Posted February 13, 2004 no ted this is not normal's issue.it is about caping curved hole. Link to comment Share on other sites More sharing options...
