Help Pls! Vray Install Error!
arkinel
Hi everyone I try to install a Vray Plugins for Max and this what I get an ERROR!:( Im currently using Windows Vista and 3ds Max Design 2009. I dont know why the Vray Plugins Installer could not write sysmtem folder on my Drive as you can see the attach image. Im current using also the Administrator User. Hoping for a response. Thank you in advance for helping me. cheers mates!:)
If you're in vista you probably need to run the installer as an administrator. Right click on the icon and it should give you the option in the fly out menu.
In general I would recommend turning of the User account control, it seems to be more of a pain than anything.
My Vista is 32bit, my 3ds Max Design 2009 is 32bit as well and i'm installing the Vray1.5 SP2 X86 plugins for 3dsMax 2009. and yes! it installed properly when i run as an administrator. but when I fire-up the MAX it gives me tons of error with .dlls and .dlts , i don't know if this version of vray is compatible with Max Design 2009 or its only for Max2009. appreciate your help guys! tnx...
I post a screen shot of the errors, this occurs during i fire-up 3dsmax. I try to configure also the plugin.ini as said from the other previous thread but didn't help me. see attach 2 for the old and new plugin.ini setup. thnx for your help guys.
Is the installer directed to the correct file path. If it is installing and you are getting these errors it seems to me like the installer is not putting the files in the right place or you don't have rights to access the files. Your plugin.ini seems correct.
I post the screen shot of the installation folders. this is the default one. thus it seems right? tnx mate.
tnx mate, i tried to edit my plugin.ini but its the same errors i get. i will try to uninstall everything and reinstall again, hope it will fix those errors. i will try also to get some answers to chaosgroup. anyway, thnx everyone for all your supports. cheers!
I've solve my problem... i took me a while to figure out and i just remember the response of Spooner04 about the User Acount Control..tnx mate..
Solution: Turn OFF the User Account Control on your Windows User Account.. that will solve all your problems heheh.. cheers.. tnx everyone.
Edited by arkinel
Problem Solve...
  • 2 weeks later...
  • 1 month later...
I have the same problem and I can't remove totally Vray... after uninstall I still have the same error messages....
Just borring... I 've stopped to work at home and I will try not to use anymore anykind of Vista or Microsofts stuff... At work every body still have XP 64 for the same reason and every things work well... Vista suck....
  • 6 months later...
I've been having this problem myself and I have at least resolved the errors from popping up but I still can't get VRAY to run correctly but oh well vray's crazy anway with the dongle shit. All you do is cut those .dlls from the 3dsmax/plugins/vray folder and paste them inside of the 3dsmax root folder or delete them whatever you want.
