another small development
well we're progressing see enclosed - but i'm having some troubles with the tiled roof
are there any textures out there to show terracotta tiling?
i've gone through mrmaterials - but it looks like i might need to 3D model the tiled roof from scratch - this client really wants a tiled roof look. :(
I reckon I would model an individual tile, get it textured properly (new tiles tend to be shiny and have that "I just re-financed my house to get a new roof!" look), and then put it on a roof slope.
Dump this into your scripts folder under:
c:\program files\autodesk\3ds max 2009\scripts
I have a floating toolbar of the few scripts that I use on a regular basis.
Then select the roof as the place to paint on, then pick the tile you've modelled and textured, then 'paint' it on.
I got this script from http://www.3d-palace.com and use it to put rivets on 'mechs and such.
You can also align a user grid to the angle of the roof and then array it. Once you get one side, select/group them and rotate/copy it to the other sloped surface.
Hope this makes sense.
-- Object Painter by Jon Weimer, 2007
-- A Revised version of Autodesk Placement Tool script
offsetY = 20
globalZero = Point3 0 0 0
globalFirstHit = TRUE
globalDistNode = #(undefined,undefined,undefined)
globalDistNodeMirror = #(undefined,undefined,undefined)
globalHairCopy = #(undefined,undefined,undefined)
globalHairCopyMirror = #(undefined,undefined,undefined)
globalLastNode = #(undefined,undefined,undefined)
globalLastNodeMirror = #(undefined,undefined,undefined)
globalLastPos = #(undefined,undefined,undefined)
globalLastNormal = #(undefined,undefined,undefined)
globalLastPosMirror = #(undefined,undefined,undefined)
globalLastNormalMirror = #(undefined,undefined,undefined)
globalLastStr = 1
globalLastRadius = 1
globalUseDist = #(FALSE,FALSE,FALSE)
globalHairPos = #(globalZero,globalZero,globalZero )
globalHairNormal = #(globalZero,globalZero,globalZero)
globalHairPosMirror = #(globalZero,globalZero,globalZero )
globalHairNormalMirror = #(globalZero,globalZero,globalZero)
globalAlignNormal = 3
globalAlignStroke = 1
globalScaleOption = 1
globalScaleNormal = TRUE
globalScaleStroke = TRUE
globalScaleStrength = TRUE
globalScaleX = 1.0
globalScaleY = 1.0
globalScaleZ = 1.0
globalSourceNode = #()
globalInstance = FALSE
matrix3 fn GetMatrix hairPos mousePos normal str radius =
tm = matrix3 1
strNormal = 1
normalBase = 1
strengthBase = 1
strokeBase = 1
strStroke = 1
strStrength = 1
xvec = Point3 1 0 0
yvec = Point3 0 1 0
zvec = Point3 0 0 1
mouseVec = Point3 1 0 0
zvec = normalize normal
mouseVec = mousePos - hairPos
mouseVec = normalize mouseVec
xvec = cross mouseVec zvec
xvec = Normalize xvec
yvec = cross zvec xvec
yvec = normalize yvec
if (globalScaleOption == 1) then
else if (globalScaleOption == 2) then
str = globalScaleX
if (globalScaleY > str) then str = globalScaleY
if (globalScaleZ > str) then str = globalScaleZ
str = Length(mousePos - hairPos)/str
xvec = xvec * str
yvec = yvec * str
zvec = zvec * str
else if (globalScaleOption == 3) then
if (globalScaleNormal) then
strNormal = str*thePainterInterface.normalScale
if (globalAlignNormal == 1) then
normalBase = globalScaleX
else if (globalAlignNormal == 2) then
normalBase = globalScaleY
else if (globalAlignNormal == 3) then
normalBase = globalScaleZ
strNormal = strNormal/normalBase
zvec = zvec * strNormal
if (globalScaleStroke) then
strStroke = Length(mousePos - hairPos)
if (globalAlignStroke == 1) then
strokeBase = globalScaleX
else if (globalAlignStroke == 2) then
strokeBase = globalScaleY
else if (globalAlignStroke == 3) then
strokeBase = globalScaleZ
strStroke = strStroke/strokeBase
yvec = yvec * strStroke
if (globalScaleStrength) then
strStrength = radius
if (globalAlignStroke == 1)then
if (globalAlignNormal == 2)then
strengthBase = globalScaleZ
else if (globalAlignNormal == 3)then
strengthBase = globalScaleY
else if (globalAlignStroke == 2)then
if (globalAlignNormal == 1)then
strengthBase = globalScaleX
if (globalAlignStroke == 3)then
else if (globalAlignNormal == 2)then
strStrength = strStrength/strengthBase
xvec = xvec * strStrength
tm.row3 = xvec
tm.row1 = yvec
tm.row2 = zvec
else
tm.row1 = zvec
tm.row2 = yvec
tm.row3 = yvec
tm.row1 = xvec
tm.row2 = zvec
else
tm.row1 = zvec
tm.row2 = xvec
else
tm.row3 = zvec
tm.row1 = yvec
tm.row2 = xvec
else
tm.row1 = xvec
tm.row2 = yvec
tm.row4 = hairPos
return tm
fn StartStroke =
thePainterInterface.undoStart()
fn PlaceStroke =
localHit = Point3 0 0 0
localNormal = Point3 0 0 0
worldHit = Point3 0 0 0
worldNormal = Point3 0 0 0
str = 0.0f
radius = 0.0f
if (globalFirstHit == TRUE) then
globalFirstHit = FALSE
undo on
for i = 1 to 3 do
if (globalUseDist[i]) then
if (globalInstance) then globalHairCopy[i] = instance globalDistNode[i]
else globalHairCopy[i] = copy globalDistNode[i]
thePainterInterface.getHitPointData &localHit &localNormal &worldHit &worldNormal &radius &str 0
globalHairPos[i] = worldHit
globalHairNormal[i] = worldNormal
if (thePainterInterface.mirrorEnable == TRUE) then
if (globalInstance) then globalHairCopyMirror[i] = instance globalDistNode[i]
else globalHairCopyMirror[i] = copy globalDistNode[i]
thePainterInterface.getMirrorHitPointData &localHit &localNormal &worldHit &worldNormal 0
globalHairPosMirror[i] = worldHit
globalHairNormalMirror[i] = worldNormal
--retrieves the last hit point
--This gets whether the stroke point actually hit the mesh
--Since the user can paint off the mesh
--Right now we ignore this and create a cylinder regardless if they are painting on the mesh or not
hit = thePainterInterface.getIsHit -1
thePainterInterface.offMeshHitPos = globalHairPos[1]
for i = 1 to 3 do
globalScaleX = abs (globalDistNode[i].max[1] - globalDistNode[i].pos[1])
globalScaleY = abs (globalDistNode[i].max[2] - globalDistNode[i].pos[2])
globalScaleZ = abs (globalDistNode[i].max[3] - globalDistNode[i].pos[3])
minScaleX = abs (globalDistNode[i].min[1] - globalDistNode[i].pos[1])
minScaleY = abs (globalDistNode[i].min[2] - globalDistNode[i].pos[2])
minScaleZ = abs (globalDistNode[i].min[3] - globalDistNode[i].pos[3])
if (minScaleX > globalScaleX) then globalScaleX = minScaleX
if (minScaleY > globalScaleY) then globalScaleY = minScaleY
if (minScaleZ > globalScaleZ) then globalScaleZ = minScaleZ
tm = matrix3 1
globalHairCopy[i].transform = GetMatrix globalHairPos[i] worldHit globalHairNormal[i] str radius
--checks if the mirror is on, if so make sure to get that point and proces it also
-- Put mirror stuff here
globalHairCopyMirror[i].transform = GetMatrix globalHairPosMirror[i] worldHit globalHairNormalMirror[i] str radius
fn PaintStroke =
mirrorWorldHit = Point3 0 0 0
str = 0.0f
radius = 0.0f
for i = 1 to 3 do
for i = 1 to 3 do
tm = matrix3 1
projVec = Point3 0 0 1
if (thePainterInterface.getHitCount() > 1) then projVec = worldHit + (worldHit - globalLastPos[i])
else projVec = worldHit
globalHairCopy[i].transform = GetMatrix globalHairPos[i] projVec globalHairNormal[i] str radius
thePainterInterface.getMirrorHitPointData &localHit &localNormal &mirrorWorldHit &worldNormal 0
if (thePainterInterface.getHitCount() > 1) then projVec = mirrorWorldHit + (mirrorWorldHit - globalLastPosMirror[i])
else projVec = mirrorWorldHit
globalHairCopyMirror[i].transform = GetMatrix globalHairPosMirror[i] projVec globalHairNormalMirror[i] str radius
for i = 1 to 3 do
globalLastNode[i].transform = GetMatrix globalLastPos[i] worldHit globalLastNormal[i] globalLastStr globalLastRadius
globalLastNodeMirror[i].transform = GetMatrix globalLastPosMirror[i] mirrorWorldHit globalLastNormalMirror[i] globalLastStr globalLastRadius
for i = 1 to 3 do
globalLastNode[i] = globalHairCopy[i]
globalLastNodeMirror[i] = globalHairCopyMirror[i]
globalLastPos[i] = globalHairPos[i]
globalLastNormal[i] = globalHairNormal[i]
globalLastPosMirror[i] = globalHairPosMirror[i]
globalLastNormalMirror[i] = globalHairNormalMirror[i]
globalLastStr = str
globalLastRadius = radius
fn CancelStroke =
thePainterInterface.undoCancel()
fn EndStroke =
thePainterInterface.undoAccept()
fn systemEnd =
PaintHairRollout.PaintButton.checked = off
PaintHairRollout.PlaceButton.checked = off
rollout PaintHairRollout "Object Placement Tool Setup" width:600 height:600
   label instruction01 "1. Select the object you want to place other objects onto and then" pos:[11,16] width:500 height:15
   label instruction02 "click here -->" pos:[25,46] width:200 height:15
   Button SourceButton "Set Destination Object" pos:[110,40] width:150 height:24
   -- label SourceObject "Destination Object:" pos:[11,160] width:120 height:15
   label instruction03 "2. Click a Pick Object button and then select an item in the viewport to" pos:[11,80] width:420 height:15
   label instruction04 "place or paint onto the Destination Object:" pos:[25,105] width:400 height:15
   pickButton Dist1Button "Pick Object 1" pos:[186,141] width:120 height:24
   pickButton Dist2Button "Pick Object 2" pos:[186,170] width:120 height:24
   pickButton Dist3Button "Pick Object 3" pos:[186,201] width:120 height:24
   checkbox UseDist1 "Position/Paint With" pos:[30,145] width:176 height:15
   checkbox UseDist2 "Position/Paint With" pos:[30,174] width:176 height:15
   checkbox UseDist3 "Position/Paint With" pos:[30,204] width:176 height:15
   label instruction05 "3. Do you want to place objects or paint with them?" pos:[11,240] width:420 height:15
   checkButton PlaceButton "Place" pos:[30,265] width:104 height:24
   checkButton PaintButton "Paint" pos:[150,265] width:104 height:24
   checkbox UseInstance "Instance Copies" pos:[270,270] width:120 height:15
   label instruction06 "--------------- Advanced User Options ---------------" pos:[80,320] width:420 height:300
   label instruction07 "4. Change tool settings -->" pos:[11,350] width:320 height:24
   button Options "Tool Options" pos:[180,345] width:120 height:24
   label instruction08 "5. Change Object Alignment:" pos:[11,380] width:325 height:24
   label Align2 " Axis To Normal " pos:[25,390+offsetY] width:192 height:15
   dropDownList AlignNormal "" pos:[130,385+offsetY] width:37 height:21 items:#("X", "Y", "Z") selection:3
   label Align4 " Axis To Stroke " pos:[180,390+offsetY] width:92 height:15
   dropDownList AlignStroke "" pos:[280,385+offsetY] width:37 height:21 items:#("X", "Y", "Z") selection:1
   label Align5 "6. Scale Objects " pos:[11,435+offsetY] width:106 height:15
   dropDownList ScaleOptions "" pos:[120,430+offsetY] width:100 height:21 items:#("None", "Uniform Scale", "Custom Scale") selection:1
   checkbox chkScaleNormal "Scale Based On Normal" pos:[28,472+offsetY] width:170 height:22 checked:true
   checkbox chkScaleStroke "Scale Based On Stroke" pos:[28,492+offsetY] width:170 height:22 checked:true
   checkbox chkScaleStrength "Scale Based On Strength" pos:[28,512+offsetY] width:190 height:22 checked:true
on SourceButton pressed do
globalSourceNode = $
on Dist1Button picked obj do
globalDistNode[1] = obj
Dist1Button.text = obj.name
UseDist1.checked = TRUE
globalUseDist[1] = TRUE
on Dist2Button picked obj do
globalDistNode[2] = obj
Dist2Button.text = obj.name
UseDist2.checked = TRUE
globalUseDist[2] = TRUE
on Dist3Button picked obj do
globalDistNode[3] = obj
Dist3Button.text = obj.name
UseDist3.checked = TRUE
globalUseDist[3] = TRUE
on UseDist1 changed state do
globalUseDist[1] = state
on UseDist2 changed state do
globalUseDist[2] = state
on UseDist3 changed state do
globalUseDist[3] = state
on UseInstance changed state do
globalInstance = state
on PlaceButton changed state do
if (PaintButton.checked) then
PaintButton.checked = FALSE
thePainterInterface.EndPaintSession()
if thePainterInterface.InPaintMode() then
PlaceButton.checked = FALSE
else
PlaceButton.checked = TRUE
thePainterInterface.initializeNodes 0 globalSourceNode
thePainterInterface.pointGatherEnable = FALSE
thePainterInterface.buildNormals = TRUE
thePainterInterface.offMeshHitType = 2
thePainterInterface.drawTrace = FALSE
thePainterInterface.ScriptFunctions startStroke placeStroke endStroke cancelStroke systemEnd
thePainterInterface.startPaintSession()
on PaintButton changed state do
if (PlaceButton.checked) then
else
PaintButton.checked = TRUE
thePainterInterface.ScriptFunctions startStroke paintStroke endStroke cancelStroke systemEnd
On Options pressed do
thePainterInterface.paintOptions()
on AlignNormal selected sel do
globalAlignNormal = sel
on AlignStroke selected sel do
globalAlignStroke = sel
on ScaleOptions selected sel do
globalScaleOption = sel
on chkScaleNormal changed state do
globalScaleNormal = state
on chkScaleStrength changed state do
globalScaleStrength = state
on chkScaleStroke changed state do
globalScaleStroke = state
on PaintHairRollout oktoclose do
thePainterInterface.endPaintSession()
-- create the rollout window and add the rollout
if FloaterExampleFloater != undefined do
closerolloutfloater FloaterExampleFloater
Floater = newRolloutFloater "Object Placement/Paint Tool" 450 600
addRollout PaintHairRollout Floater
Found some links for you also on modelling tiles:
http://www.cg-blog.com/index.php/2007/04/02/how-to-model-tiled-roof.htm
http://www.robeccaproductions.com/Spanish_Tile_toot.htm
http://www.turbosquid.com/FullPreview/Index.cfm/ID/151967
(a roof tile model for $22)
The guy selling the roof tile says there are tutorials on his 2 websites and lists them, but they don't work any more.
Hi Stan,
Looking better and better each render. I'd say the best way to get a correct tile (the method I use) is to try and get the specs for the actual tile which is going to be used. The architect should definitely know exactly which tile and from which company will be used. You can usually find the measurements on the manufacturers site and go from there. If not, call them up and get them to send you a product pack with specs for their products. Most aussie companies are rather obliging. I have gotten free colour swatches and product range packs from dulux, solver and James Hardie. Very handy as my clients use James Hardie and Bluescope stuff for 95% of the materials for each project.
I'll have to have a go of that script Joel some time. Tiles are the worst part of any job for me. Thanks for posting.
James - it's a great little script. You can paint grass, hair, rivets, any sort of detail that you need.
First roof tile I've ever made.
I drew an arc spline then edited it to get the desired profile.
I then extruded it and applied a slight amount of taper.
I had my first row of tiles.
I then dragged a copy behind it and made it 'pop a wheelie' of 2.5 degrees.
I allowed an overlap of about 1.5 inches (trivia: you can enter another unit of measurement (like, Inches or ") even if you are in metric. Max does it and then displays the distance in metric)
I then copied the 2nd row however many times I needed to cover my roof.
I had a column.
I then copied the entire column to the side however many times I needed to cover my roof.
Since I never collapsed my stack, I can easily go in and edit the basic shape of the initial spline that formed the first tile. And as long as I don't exceed the overall length by too much, I should be able to change the basic shape of the entire roof in seconds.
I've attached my max file if anyone is interested.
Hey guys,
here is the render with the tiles enclosed. Thankfully CSR had the 3D CAD model on their website and so it was a matter of bringing this in to the MAX model.
my model though has now ballooned from 89MB to 447MB!!! so i wonder how long final 4000x3000 px render will take.
thanks again for all your help with this one :cool:
Depends on how you adjust the roofing reflections - I'd recommend using the "Highlight Only" if you want the glazing to look clean and new.
The Merc needs to be polished too, it looks a little dull for a modern black car. You should be able to see the house reflected down the passenger side. It wouldn't hurt to add some gloss to the tyres too, makes them look like they've just had a wipe with ArmourAll.
If you are going to have a reflective driveway, give it some more blur and turn Fresnel on, IoR at about 1.35.
Head over to http://www.cgtextures.com and get some good asphalt and concrete textures for your road and footpath - they are in the foreground so the textures need to be good quality.
It's looking good and progressing well. Keep it up, Stan.
Edited by shaneis
Looking much better Stan:cool:. I'm not sure if this is in your control or not, but i think the 'postage stamp' shape needs to go. Maybe try a more 'landscape' view. I realize you can't change it too much because the two houses side by side almost form a square, but i think taking a little off the top and bottom would make a big difference. Your getting some good advice from the other guys so that's all i have to pick. Good to see you moving forward with it.
Yes it is worth modelling, unless it's a small part of the final picture and it looks much better than a bump map. If you use the approximation features in your renderer, you have control over the level of detail/ tessellation.
The following link is an interior I did with exposed beams and roof sheeting. Unfortunately I don't have an exterior example.
http://www.cgarchitect.com/vb/attachment.php?attachmentid=27936&d=1216641031
Sorry Stan, back to your thread.
