johnnlo Posted October 13, 2008 Share Posted October 13, 2008 hi guys, im starting to experiment with rhino on my spare time, what commands / methods would allow me to generate certain forms that transition themselves from one to another? thanks for the info. Link to comment Share on other sites More sharing options...
mbowers Posted October 13, 2008 Share Posted October 13, 2008 I just downloaded the beta copy of Grasshopper, and also using a demo version of RhiKnowBot. They both deal with computational parametric modeling. I'm new with Rhino and am learning myself. Hope that helps. Link to comment Share on other sites More sharing options...
SSPEIPER Posted October 14, 2008 Share Posted October 14, 2008 Rhino is brilliant for Architects like me... Very easy to use - unlike 3ds Max - although having said that ive not really given Max a whole lot of time... Does anyone know of a converter to bring Max models into Rhino? Link to comment Share on other sites More sharing options...
SSPEIPER Posted October 14, 2008 Share Posted October 14, 2008 Just out of interest! are you guys using Rhino for both design and model? For me personally, I draw and design in AutoCAD 9 and then transfer the linework into Rhino - to then extrude, model etc... Then again 3D modelling as a design tool is invaluable - to sort out those problem areas that cant be seen in flat 2D plans. Link to comment Share on other sites More sharing options...
Antisthenes Posted October 14, 2008 Share Posted October 14, 2008 Does anyone know of a converter to bring Max models into Rhino? that would be nice but we know how protective and counterproductive a certain company is with it's file formats. there is also ParaCloud and to a lesser extent VisualARQ. I am going to get my hands dirty with that RhiKnoBot plugin asap. http://www.rhino3d.com/resources/display.asp?language=&listing=1033 http://www.visualarq.com/ yup design, model & document Link to comment Share on other sites More sharing options...
Fran Posted October 15, 2008 Share Posted October 15, 2008 Then again 3D modelling as a design tool is invaluable - to sort out those problem areas that cant be seen in flat 2D plans. I prefer to export from Max in OBJ format with the quads option. I collapse the modifier stack first though. Link to comment Share on other sites More sharing options...
Antisthenes Posted October 15, 2008 Share Posted October 15, 2008 Obj is a newer format with more support than 3ds correct? is there anywhere a break down in comparing these 2 exists? Fran have you tried the new Quad Meshing plugin for Rhino? Link to comment Share on other sites More sharing options...
johnnlo Posted October 16, 2008 Author Share Posted October 16, 2008 iges is the best format to convert Link to comment Share on other sites More sharing options...
Antisthenes Posted October 16, 2008 Share Posted October 16, 2008 or STEP if you want to keep nurbs but when is the last time i saw a natively created nurbs object in max i needed to put out to another program? never, autocad: all the time, as autocad is a nurbs modeler for windows too and in that case SAT ACIS is the format you want to go out in. Link to comment Share on other sites More sharing options...
Fran Posted October 16, 2008 Share Posted October 16, 2008 Obj is a newer format with more support than 3ds correct? is there anywhere a break down in comparing these 2 exists? Fran have you tried the new Quad Meshing plugin for Rhino? The thing about exporting 3ds from Max is the 64k poly limit. I have not tried the quad meshing plugin. I can't see where it is of much use to me. Link to comment Share on other sites More sharing options...
SSPEIPER Posted October 17, 2008 Share Posted October 17, 2008 I have still yet to upgrade from Rhino 3.0 to 4.0 However I am wanting to try and take my models done in Rhino into 3DS MAX. What is the best way to do this? Also, I put alot of 'POSER' people models into my Arch-Viz scenes, so how can I transfer what is a polygonal mesh with alot of pieces into MAX from Rhino? I have 3DS MAX 8, and every time ive tried to import either IGES, OBJ or 3ds from Rhino it just wont open. Do I need a converter plugin? What are the pros and cons of me doing the following; Upgrading to Rhino 4.0 & Vray for Rhino 'OR' Upgrading to Rhino 4.0 and then exporting it all to 3ds MAX and render there? Thanks in advance! Link to comment Share on other sites More sharing options...
SreckoM Posted October 19, 2008 Share Posted October 19, 2008 One way is to convert surfaces into meshes than export it as obj, it works for me every time. Other way is to use nPower plugin for max, I think it adds possibility to import 3dm files into max, but didn't try this, I just hate how max handle NURBS. Also, I put alot of 'POSER' people models into my Arch-Viz scenes, so how can I transfer what is a polygonal mesh with alot of pieces into MAX from Rhino?Why just you import it directly into max? What are the pros and cons of me doing the following; Upgrading to Rhino 4.0 & Vray for Rhino 'OR' Upgrading to Rhino 4.0 and then exporting it all to 3ds MAX and render there?PROS Well, first of all better manipulation of geometry, when you export it as mesh (especially if it is complex) it just pain to do some changes later on it in Max. There could be some mapping problems, UV things, strange artifacts, etc, at least that is what I experienced. Model as mesh isn't always that good as NURBS. Much of features of VrMax are implemented in version in Rhino. CONS There is some Vray features that are not implemented and that existing in Max (VfM is much mature software than VfR) like Vray fur, partial implementation of Vray IES, vray proxies etc. 100% of work I do in Rhinoceros I render it with Vray for Rhinoceros. I just do not have need to export it in Max or any other package. But that is subject thing ... Link to comment Share on other sites More sharing options...
