centrix Posted October 20, 2008 Share Posted October 20, 2008 Hi guys, this is my first post here, unfortunately containing a problem i can`t solve by myself:( So, I tried out a VrayScatter demo today, made 2000 instances all over a plane (displaced grass,2D), applied material and tried to render it in 1900x900. It crashed immediatelly, without an error. The settings: Prim. bounce: irradiance map (low preset) Sec bounce:light Cache color mapping:exponential default lights off all other settings left on default The proxies were quite heavy on polys. The System: Asus P5Q deluxe Core2Quad 9550 8GB RAM Vista x64 512 MB Graph. card 3ds max 2009 x64 SP1, all hot fixes installed V-Ray 1.50 SP2 Max crashed when it hits aprox 2.9 GB Ram. My question is, why is this happening under x64 system with 8GB of RAM. I know that vray had to handle some mil. of polys, but still, why it crashed under 3 GB of RAM? Switching sec. bounce to none made no difference (I know light cache uses the most of the memory, while calculating). Thanks in advance, hope you folks know, what to do, i would appreciate every idea. Link to comment Share on other sites More sharing options...
tayrona Posted October 21, 2008 Share Posted October 21, 2008 http://www.cgarchitect.com/vb/32775-how-manage-ram-useage-avoid-crashing.html Link to comment Share on other sites More sharing options...
centrix Posted October 21, 2008 Author Share Posted October 21, 2008 Thanx Tayrona, but this did not answered my questions neither solved my problem:( I have x64 OS and 8GB of ram, x64 max and x64 vray and I just can`t imagine, where could be the prob. Also tried dynamic with 4,5,8k MB, still no effect Link to comment Share on other sites More sharing options...
martincg Posted October 21, 2008 Share Posted October 21, 2008 and without displace crashing too? Link to comment Share on other sites More sharing options...
centrix Posted October 21, 2008 Author Share Posted October 21, 2008 Yes, it crashes with disabled displace also. Although i managed to render 1 frame from out of 10, but i guess it was just a brighter moment, it fails to render on the next one. But thanx for reply, appreciate it. Link to comment Share on other sites More sharing options...
centrix Posted October 21, 2008 Author Share Posted October 21, 2008 Ok guys, I think I managed to control it without a crash. What I did first, was raising virtual memory to 12.5GB and then, switched to Static geometry in Vray, changed bucket size to 32, left sec. bounces to none, and voila, it worked like a charm! The scene consists of 15000 instances, every instance is 500 000 poly large, but it was finally stable!Tried to render in bigger res(2500x1500), no prob at all. Render times fairly exceeded 11 minutes per frame (1400x600), which is acceptable. I`d like to ask, what are the disadvantages of using static geometry? Link to comment Share on other sites More sharing options...
manta Posted October 22, 2008 Share Posted October 22, 2008 I might be wrong about this...but if your whole scene is made up of proxies, then your already using dynamic geometry, so switching to static won't make any difference...my understanding is when you have ordinary geometry, switching to dynamic essentially turns those into proxies...again I might be misunderstanding that myself... Link to comment Share on other sites More sharing options...
centrix Posted October 22, 2008 Author Share Posted October 22, 2008 This is strange,I switched back to dynamic, set it to 4000MB (the same settings as before, when i was experiencing crashes), and it rendered. Turned sec. bounces to light cache (expecting it to crash instantly) and it computes without a prob. These lead me to a conclusion, that what really helped, was raising the virtual memory from 8.5GB to 12.5GB, which is kind of odd, i don`t really understand this. Someone to answer this? Link to comment Share on other sites More sharing options...
