chow choppe Posted October 21, 2008 Share Posted October 21, 2008 (edited) hi all here is the improved animation after responses to my previous threads I have used quite fine settings in the animation but still i can see very fine noise in the animation In the bottom of ceiling and other flat areas like the grey wall where there is standing lamp http://www.the3rddimension.in/uploads/anim.rar In quicktime free version it wont play at full res. so use another playerr like VLC or nero player to play it Settings i used are: LC 2000 smpld size 0.02mm Screen mode...AGAIn world mode was crashing it Ir set to medium animation Hsph 50 inter samples 40 Image sampling adaptive amount .085 noise threshhold 0.01 antialiasing Adaptive DMC 1,4 area filter also i have used around 24 subdivisions for my lights Is this noise acceptable or it can be still made flicker free Thanks Edited October 21, 2008 by 3dsmaxed Link to comment Share on other sites More sharing options...
STRAT Posted October 21, 2008 Share Posted October 21, 2008 plays fine for me in QT. but it's so difficult to judge anything here as the quality of resolution and compression is really poor. looks much better at half original size. what noise and flicker are you talking about? if it's the AA flicker then my answer is in the above paragraph. and acceptable for what? what's the purpose of this animation? if it's for a client then it certainly isn't acceptable. learn how to compose and compress and animation. but for the gi it looks fine. all you now need to do is further learn how to optimize your vray settings. it's only a camera animation, so the irradiance and lightcache maps can be pre-cached at half size to save masses of render time. Also, the 24 subdivs in the lights are way too high. 8 will do. Generally, AA of 1x8 is good. 1x4 is a bit low. Link to comment Share on other sites More sharing options...
chow choppe Posted October 21, 2008 Author Share Posted October 21, 2008 Strat tahst what i told quicktime plays it but if u dont have quicktime pro it will play at half the resolution.\ see it another player and u will see good quality thanks Link to comment Share on other sites More sharing options...
STRAT Posted October 21, 2008 Share Posted October 21, 2008 ok. (i do own QT pro though). yes, plays fine in VLC. Visually it looks fine. you need higher AA to get rid of the edge shimmer and treble the amount of blurry samples on the wall to get rid of the reflective grain. i'm presuming you're using the correct camera anim render technique too? Link to comment Share on other sites More sharing options...
chow choppe Posted October 21, 2008 Author Share Posted October 21, 2008 u mean i shud make it 1,6 for adaptive DMC? and my walls and ceilings are not reflective. so i dont understand where is the noise coming from Link to comment Share on other sites More sharing options...
