Windows question
I set up a ten machine network about a year ago and aside from a couple of squeaks, it was pretty easy. I've re-installed windows on my workstation after a hard drive failure.
Im now trying to re-set up the network and hving some problems....
All the machines can only see the 'shared folder' on other machines. no drives.
I cant map a network drive on my own machine.
Seems like Im missing something. Im guessing its a permissions thing.
Any help? I hate networking.
Tom.
[EDIT] I cant even specify a save location in max on my local machine using UNC over the network.
Also, if i right click on a folder on my machine and go to shares and security, I can change it to 'allow sharing' which makes it visible on the network. Where do I change this for a DRIVE and make everything in the drive sharable and editable.
I hate networking.
Edited by Tommy L
When you click on "My Network Paces", on the side bar you should see "Add a network Place"
Follow the instructions, Select "Choose another network location", select "browse", Seclect "Entire Network". All of the machines that have shares should be visible.
If not....I'm stumped.
However, I have not "mapped" a drive since Windows 3.11. Max has no problem with the "Network Place" method....except for local folders, which Windows removes the UNC to be a local drive (grrrrrrr)
Hope this helps
