parker2740 Posted October 27, 2008 Share Posted October 27, 2008 I am rendering a building that has a a glass curtain wall and there are angles that allow you to see through to the back side of the glass on the other side. When it renders instead of seeing sky, it renders white. I have turned off the "back face" option in the glass material and still havent solved it. Short of turning those back faces off, is there a setting that will allow the sky behind. TIA Link to comment Share on other sites More sharing options...
rmccoy Posted October 27, 2008 Share Posted October 27, 2008 can you post a screen grab of your material settings? Link to comment Share on other sites More sharing options...
parker2740 Posted October 27, 2008 Author Share Posted October 27, 2008 Here is the screen grab and the effect. What do you think? Link to comment Share on other sites More sharing options...
BrianKitts Posted October 27, 2008 Share Posted October 27, 2008 I think you may want to reinvestigate your glass material. Have you tried a more realistic glass IOR for your refraction settings. I'm assuming you have a fresnal falloff map in your reflection channel? The following is a starter material for glass.... always works quite well. Link to comment Share on other sites More sharing options...
parker2740 Posted October 27, 2008 Author Share Posted October 27, 2008 I had the IOR set to 1.6 and it was giving me a weird warping effect at some of the corners so I dropped it down. Thanks for the settings, Ill try it Link to comment Share on other sites More sharing options...
