Three D Posted October 28, 2008 Share Posted October 28, 2008 hi. i'm trying to use vray dirt to add realism to my scene but no matter what settings i use there's no sign of the vray dirt effect in any if my renders. i've tried vray dirt as the main diffuse material and also in a vray blend material but with no joy. would somebody be kind enough to post a simple scene with a vray dirt material that they know to work and i'll see if i can get it to work on my pc please. thanks for your help. Link to comment Share on other sites More sharing options...
kippu Posted October 28, 2008 Share Posted October 28, 2008 did you try changing the default units on vray dirt? make it higher or smaller and see if affects the scene? Link to comment Share on other sites More sharing options...
Three D Posted October 28, 2008 Author Share Posted October 28, 2008 thanks kippu. i've tried all different values for all the different settings but there's still no sign of the dirt effect. It's such a simple tool so i'm lost as to why this is happening. Link to comment Share on other sites More sharing options...
Tim Fairbanks Posted October 28, 2008 Share Posted October 28, 2008 (edited) Have you verified the dirt effect radius? It should be in scene units. edit--> oops, just noticed that kippu mentioned that above. sorry Also, if your objects have been scaled up or down, the VrayDirt may not correctly interpret each object's true size in world coordinates. Vray online docs/examples might help: http://www.spot3d.com/vray/help/150SP1/examples_vraydirt.htm http://www.spot3d.com/vray/help/150SP1/vraydirt_params.htm TimF Edited October 28, 2008 by TimF Link to comment Share on other sites More sharing options...
BrianKitts Posted October 28, 2008 Share Posted October 28, 2008 TimF said: Also, if your objects have been scaled up or down, the VrayDirt may not correctly interpret each object's true size in world coordinates. resetting the object's Xform will correct that issue. Link to comment Share on other sites More sharing options...
Three D Posted October 29, 2008 Author Share Posted October 29, 2008 thanks guys. i had tried all your advice before i originally posted the thread. i did everything as per spot3d.com help and any vray dirt tutorials i found on the net. anyway, i'm back in the office now, the problem was on my home pc, and vray dirt on this office pc works fine using the same 3ds max design, vray 1.50 sp 2 and dongle as i use on the home pc. so i'll bring a file home this evening with the dirt working and see if it works at home. thanks again for your help. Link to comment Share on other sites More sharing options...
zewanil Posted July 1, 2009 Share Posted July 1, 2009 hi there have you finally found the solution to your problem i am having the same problem and i really dont know whats the solution thanks for helping P Link to comment Share on other sites More sharing options...
Three D Posted July 2, 2009 Author Share Posted July 2, 2009 i never found a solution zewanil. i just avoided using the vray dirt on that project and the next time i used it, some months later, it worked fine - using the same max template. if i get a chance i'll track back and see if it works on that old project now. Link to comment Share on other sites More sharing options...
lilcutie Posted December 10, 2009 Share Posted December 10, 2009 hello i'm new in the 3d world and i would like to know more about vraydisplacementmod. thanks a lot. Link to comment Share on other sites More sharing options...
WAcky Posted December 10, 2009 Share Posted December 10, 2009 lilcutie said: hello i'm new in the 3d world and i would like to know more about vraydisplacementmod. thanks a lot. Firstly you should probably check out these links: http://www.cgarchitect.com/vb/4587-forum-rules-user-agreement.html http://www.cgarchitect.com/vb/search.php http://www.spot3d.com/vray/help/150SP1/displMod_params.htm Link to comment Share on other sites More sharing options...
remKa Posted December 15, 2009 Share Posted December 15, 2009 You have to replace your vraydirt20(xx).dlt in autodesk/3DSMAX20(xx)/plugins/vrayplugins, you will find it on the web Link to comment Share on other sites More sharing options...
tommyjj Posted December 21, 2009 Share Posted December 21, 2009 what type of scene are you trying to use the dirt map on? you have to make sure you're not using the same colour for occluded and unoccluded, also check the scale you're using. If the scene is only 1m across and you're using the default radius of 10m, you're not going to see any effects. Link to comment Share on other sites More sharing options...
zewanil Posted December 21, 2009 Share Posted December 21, 2009 thanks eveyone .. finally it was my version of vray witch was not good happy holidays Patrick Link to comment Share on other sites More sharing options...
