Tim Nelson Posted October 29, 2008 Share Posted October 29, 2008 Does anybody know how to take a section like this and have it repeat along a line in max? Its a top view of a wall that repeats every 15'. And since a lot of the walls are at angles, it would be great if I could just draw the lines, and then apply this profile to the lines and extrude it. Any thoughts? Link to comment Share on other sites More sharing options...
Stephen Thomas Posted October 29, 2008 Share Posted October 29, 2008 (edited) Have you tried using the spacing tool? Create one panel then your spline with vertices every 15'. Select your panel, then Tools > Spacing Tool and select spline, put number of panels, done. Should work fine. You might need to adjust the start and end offsets as well. Edited October 29, 2008 by stef.thomas Link to comment Share on other sites More sharing options...
Tim Nelson Posted October 29, 2008 Author Share Posted October 29, 2008 Great idea, thanks! Link to comment Share on other sites More sharing options...
