MeshSmooth
Sergio
Hi all!
I am recreating some furniture elements, peaces are quite square, but ther are little bit rounded on the edges. I used box modeling approach,
my idea was to round edges using Smooth or meshsmooth modifier. A got a wierd image with "too smooth" edges.
There is wire frame of the "starting" image:
I presume, that I did not start model correctly, so final image can not be good. Can anybody help please :( .
Regards Sergio!
Thax Strat on very fast answer!
I was looking for chamfer modifier and I am bit confused. Is chamfer modify on mesh level or in spline level?
If it is on the spline level, that will make modeling quite lenghty...
Regards Sergio!
Thanx Strat!!!, Thanx Craig!!!
I finally figured up. It is quite tricky selecting edges, takes some time, unless there is a tool to select outside edges ;)
Because selections, seems much easyer Craigs idea of selecting and applying few times(while using the same selection).
Guys thank you very much, that was very good! :)
Regards Sergio!
