proces2 Posted April 2, 2003 Share Posted April 2, 2003 i am using the create polygon function (in sub-object mode) for an editable mesh to create some geometry (in Max 5). it is only letting me create a polygon using vertices that already exist within the object. with VIZ 4, i can create a polygon and snap to any vertex in the scene on any other object. is there some way to switch it to the way VIZ 4 works? sean Link to comment Share on other sites More sharing options...
Craig Ramsay Posted April 3, 2003 Share Posted April 3, 2003 Im having a bit of trouble understanding your problem, could you post a few screen shots so we can help you? Cheers Craig Link to comment Share on other sites More sharing options...
proces2 Posted April 3, 2003 Author Share Posted April 3, 2003 Hope these help explain the issue: http://www.cgarchitect.com/forum/filepush.asp?file=polygon_max5.jpg http://www.cgarchitect.com/forum/filepush.asp?file=polygon_viz4.jpg THe MAX 5 image shows the problem i am having and the VIZ 4 image shows how i am hoping it can work in MAX 5. Thanks. sean Link to comment Share on other sites More sharing options...
Hiroshi Posted May 16, 2003 Share Posted May 16, 2003 Sorry about the late reply, but you could use the "attach" feature in the edit mesh rollout. I assume you are trying to attach the flat face and make it a triangular shape to the box on the right. Link to comment Share on other sites More sharing options...
proces2 Posted May 16, 2003 Author Share Posted May 16, 2003 not really. i am simply trying to be able to snap to the vertices on other objects within the scene (vertices that are NOT apart of the selected object) while in sub-object - create polygon mode. its something that is possible (and amazingly handy) in VIZ 4, but doesn't seem to be in MAX 5. sean Link to comment Share on other sites More sharing options...
