innerdream Posted November 2, 2008 Share Posted November 2, 2008 I'm not getting good results. I am putting it in a material color slot and apply that to a sky object. Is that wrong? Tips? Link to comment Share on other sites More sharing options...
AJLynn Posted November 2, 2008 Share Posted November 2, 2008 I used to use an inverted sphere for this, but then they came out with the procedural sky a version or two ago... have you tried that? Use Objects menu - Sky - Create Sky then you can use Load Sky Preset (lower right screen area with the Sky selcted) to get a starting point. It's in HDR. Maybe somebody here who uses Cinema more than I do could explain the best way to use an HDR file?... Link to comment Share on other sites More sharing options...
innerdream Posted November 2, 2008 Author Share Posted November 2, 2008 I used to use an inverted sphere for this, but then they came out with the procedural sky a version or two ago... have you tried that? Use Objects menu - Sky - Create Sky then you can use Load Sky Preset (lower right screen area with the Sky selcted) to get a starting point. It's in HDR. Maybe somebody here who uses Cinema more than I do could explain the best way to use an HDR file?... I'll try that too, thanks. I found a tutorial on hdri here: http://www.maxoncomputer.com/tutorial_detail.asp?tutorialID=241 Link to comment Share on other sites More sharing options...
innerdream Posted November 2, 2008 Author Share Posted November 2, 2008 Here's one with the "Sky" from within C4D, looks pretty good I think. 3D Allusions Challenge Model. Link to comment Share on other sites More sharing options...
Frosty Posted November 3, 2008 Share Posted November 3, 2008 What Robert said, place HDRI in the Luminance channel. Also, if you aren't using lights, turn off the auto-light feature. Link to comment Share on other sites More sharing options...
innerdream Posted November 3, 2008 Author Share Posted November 3, 2008 What Robert said, place HDRI in the Luminance channel. Also, if you aren't using lights, turn off the auto-light feature. Thanks for that. I did try this and the images were very blotchy due to the hdri. The tutorial link I posted explains how to address this. Cheers. Link to comment Share on other sites More sharing options...
