Mapping problem
jucaro
Hi guys, I'm wondering how does one go about this mapping problem?
To simplify and illustrate:
The object is a box and I would like to project Planarly the diffuse and opacity map on top, but at the same time I would like to project the bump map planarly only on the sides without breaking apart the object into different elements. :???:
some input would be great
multi sub id--been there done that but the effect i really want is that the opacity and diffuse map to affect the sides to, but the bump map to affect only on the sides.
i'll post a modified screen shot of what i'm trying to attempt later.
I think what you need to do is have to two different UVW Mapping to the same object.
Here's how:
Have the first UVW set Planar mapping from the top and set the Map Channel to 1. In your material, your diffuse map and your opacity map should already be set to the default Map Channel 1.
Next, apply a second UVW map with Planar projected to the side of the object, but set it's Map Channel to 2. In the same material as before, go to your bump map and change it's Map Channel to 2.
Now you have different maps of the same material mapped to different ways.
Hope this helps.
Colin
I figured out how to go about it. But I'll try CRD's solution too and see what happens as I havent tried mapping using channels yet. I'll post some shot(s) soon.
Its nice to see different solutions from different people.
Thanks guys :winkgrin:
