sugesh Posted November 5, 2008 Share Posted November 5, 2008 HI everyone i am facing a probilam when i render with v ray sky light showing some of big white spots i tryed changing all colour mapping elements but still its not working pease help me thank you Link to comment Share on other sites More sharing options...
Trevor Tizard Posted November 5, 2008 Share Posted November 5, 2008 Is your sun set to invisible? Link to comment Share on other sites More sharing options...
BrianKitts Posted November 5, 2008 Share Posted November 5, 2008 does the vray log list materials being returned as "overbright" and are you using standard or vray materials? Link to comment Share on other sites More sharing options...
sugesh Posted November 5, 2008 Author Share Posted November 5, 2008 Is your sun set to invisible? no its visibile... for water i used two layers of mesh and when ever i use glass meterials its effecting me in five times and i am using vray materials to thank you for your reply Link to comment Share on other sites More sharing options...
sugesh Posted November 5, 2008 Author Share Posted November 5, 2008 does the vray log list materials being returned as "overbright" and are you using standard or vray materials? using v ray materials and finaly i converted the file to vray there is no standard materials thank you for your reply Link to comment Share on other sites More sharing options...
e[dub] Posted November 6, 2008 Share Posted November 6, 2008 I have experienced something similar, and I think it's caused by low reflective caustic settings - try turning off reflective caustics, and possibly refractive caustics as well. I could be totally wrong though, as I use Vray for Cinema4D, and it might not be the same problem, but I thought I'd through the possibility out there. Link to comment Share on other sites More sharing options...
sugesh Posted November 6, 2008 Author Share Posted November 6, 2008 ;230943']I have experienced something similar, and I think it's caused by low reflective caustic settings - try turning off reflective caustics, and possibly refractive caustics as well. I could be totally wrong though, as I use Vray for Cinema4D, and it might not be the same problem, but I thought I'd through the possibility out there. HI erik west this is working fine now when i turned off caustic reflective there is no white spots. i was facing this issues when ever i am using glass. thanks a lot. but for this time i need to get some water caustics also if you dont mind can you give me exact settings of caustic please and have a look my images thank you sorry for my bad english Link to comment Share on other sites More sharing options...
Jackie Teh Posted November 6, 2008 Share Posted November 6, 2008 try off the reflective in your light setting. Link to comment Share on other sites More sharing options...
