chow choppe Posted November 6, 2008 Share Posted November 6, 2008 Hi all is there any way by which we can pause a rendering and then resume During rendering the tab shows the pause button but its freezed and not usable Thanks Link to comment Share on other sites More sharing options...
dean@pikcells Posted November 6, 2008 Share Posted November 6, 2008 i think you can only pause when rendering an animation, and it will only pause after completing the current frame. Link to comment Share on other sites More sharing options...
SandmanNinja Posted November 6, 2008 Share Posted November 6, 2008 yup Link to comment Share on other sites More sharing options...
Jackie Teh Posted November 6, 2008 Share Posted November 6, 2008 press "Esc" Link to comment Share on other sites More sharing options...
chow choppe Posted November 7, 2008 Author Share Posted November 7, 2008 press "Esc" esc cancels the rendering, doesnt pause it Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 7, 2008 Share Posted November 7, 2008 Only Scanline Renderer allows you to pause the process. If you're using VRay or other engine, you won't be able to pause it. Link to comment Share on other sites More sharing options...
tecton3d Posted November 7, 2008 Share Posted November 7, 2008 Only Scanline Renderer allows you to pause the process. If you're using VRay or other engine, you won't be able to pause it. For what it's worth, Final Render let's you pause mid-render. Link to comment Share on other sites More sharing options...
heni30 Posted January 18, 2010 Share Posted January 18, 2010 Hi, If this is an emergency (pressed cancel by accident, or like in my case I wanted to stop so I could export the file quickly to a thumb drive) you can save what you have. Then when you're ready to restart put 100% black planes in front of the camera covering the part that has already been rendered. When it starts up again the black areas will take no time to render then when the uncovered parts render you can save the file and splice it to the file you had saved before. Necessity is the mother................... Link to comment Share on other sites More sharing options...
ihabkal Posted January 18, 2010 Share Posted January 18, 2010 the first few versions of vray allowed to pause in mid render. oh the good days... Link to comment Share on other sites More sharing options...
