Gander0 Posted November 7, 2008 Share Posted November 7, 2008 Hi folks, Is there a way to model in see through wireframe mode whilst having non wire frmae elements in a scene. e.g. poly-modelling a facade against a jpg mapped onto a plane. Many thanks for any help! Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted November 7, 2008 Share Posted November 7, 2008 I'm having initial success with two methods: - Create a material with as much opacity as you need, apply it to the "wireframe" object. - Select the object. Right click. Object properties. See Through. Both methods then want edged faces turned on in the display. Shortcut: F4. Link to comment Share on other sites More sharing options...
Gander0 Posted November 9, 2008 Author Share Posted November 9, 2008 Many thanks Peter, Will have a look at those Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted November 10, 2008 Share Posted November 10, 2008 Or, on the standard material there's a checkbox "wire" that does the job. BUT it shows tri's and doesn't shade the whole face when selected, so maybe you don't like it. Link to comment Share on other sites More sharing options...
