SMR3 Posted November 9, 2008 Share Posted November 9, 2008 Hello! I just started to work in RS2009 and right now I have a project called reservoir. I have lots of different reinforcement (or rebar) shapes, holders. I must draw a detailed shape draft with all its measures and angles, so the steel factory can bend them. I tried to place rebars in Legends layout, so these shapes wouldn't count in the specifications, but it was not possible. Is there other way I can make a detailed drafts of these shapes? Second question is, that these shapes I have, are located in different walls, slabs that are oriented in all ways. I have a problem with adding earlier sketched shape to new walls or foundations, the thing is, that this shape is very flexible, and can take other shape and I even wont notice it. To deal with this i made this shape a as a group, but every time I have a new shape with other "quantity and spacing" values, I have to duplicate and any how I found that in one group the shape have other length than in first one, although group names are the same. Have anyone worked with the "rebars" and understands what I'm talking about. Good help would be verry appreciated.. it is 0:39 but I'm still in the work trying to fix it, becaus deadline is comeing fast.. Best regards.. Link to comment Share on other sites More sharing options...
Mario Pende Posted November 10, 2008 Share Posted November 10, 2008 Go for Nemetschek Allplan! Link to comment Share on other sites More sharing options...
analletamby Posted December 2, 2008 Share Posted December 2, 2008 Hi I started working on Revit Structural 2009, Rcad extension. It seems that there are issues when you must use the shape code. First of all when detailing a member, you are given a set window to work from, But that window does not have the option for the shape code, Meaning you cannot define a shape code. But if you go back to the drawing you are allowed to modify the bar which allows one to define a shape code, The problem is when you export to Autocad Structural Detailing 2009 for and it generates the schedule and drawing the shape code does not appear. I have tried deffent option and have not manage to make it work. Anyone with some brigth ideas is most welcome. I have been on revit for a month and the whole process has been self thougth. I challenged anyone who thinks they have a solution Cheers Link to comment Share on other sites More sharing options...
