chortik Posted November 12, 2008 Share Posted November 12, 2008 Hi, I have a problem with v-ray frame buffer while rendering in larger resolutions, like 3000*2500 and more. It seems to crash if there is some serious geometry in my file. It did not do it, when I used max 8 and v-ray 1.5 then it was ok, but after changing to 2008 and 2009 all these problems occurred. Urgent help is needed. Best regards, C. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 12, 2008 Share Posted November 12, 2008 Are you saving to a VRay Raw Image file and turning off the Memory Frame Buffer option? Link to comment Share on other sites More sharing options...
chortik Posted November 12, 2008 Author Share Posted November 12, 2008 Hi Rick, I don't save them as Vray Raw Image files and Memory Frame Buffer option is on. Best regards, C. Link to comment Share on other sites More sharing options...
chortik Posted November 12, 2008 Author Share Posted November 12, 2008 I tried to change frame buffer parameters but it did not help. Crash takes place when rendering task is in phase: Preparing global light manager Link to comment Share on other sites More sharing options...
Tim Fairbanks Posted November 12, 2008 Share Posted November 12, 2008 Running out of memory? In Windows XP 32-bit, max will crash at about 1.8gb of memory use (per application, not total memory use). Keep an eye on your task manager if you suspect a memory related crash. TimF Link to comment Share on other sites More sharing options...
chortik Posted November 12, 2008 Author Share Posted November 12, 2008 Running out of memory? In Windows XP 32-bit, max will crash at about 1.8gb of memory use (per application, not total memory use). Keep an eye on your task manager if you suspect a memory related crash. TimF In task manager it shows that memory usage burst to sky before it will crash. Any tricks to avoid that? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 12, 2008 Share Posted November 12, 2008 What's the poly count? Link to comment Share on other sites More sharing options...
chortik Posted November 12, 2008 Author Share Posted November 12, 2008 more than 2 mil. Link to comment Share on other sites More sharing options...
logesh_v Posted November 13, 2008 Share Posted November 13, 2008 hey , y dont u increase ur page file size? there are many reasons for max crashing at heavy scenes... 1) major cause i have seen is because ppl use graphic mode as direct3d...change this to Open GL 2)if ur max crashes still increase ur page file size.... rt clk my computer--> advanced tab-->clk settings under ur performance.-->then clk advanced and select Change under the virtual memory..--> increase ur maximum size to the recommended size...ie., ur page file can be 1.5 times of ur physical ram present.... 3) if u still have problems...then u better change to 64 bits...OS and 3dsmax regards, V.logesh Link to comment Share on other sites More sharing options...
