Interior MR
CarlBat
Agree with the other comments although your settings could be tweaked a bit
may I suggest
FG
Diffuse Bouce 0 - When using Photons any bounces over 0 are disregarded at rendertime
Photons
Max no of Photons per sample 1500
Optimize for FG - ON
Trace Depth 30
Average GI Photons per Light 50000
Turn Gamma ON
Vignetting 2 (add more in Photoshop if desired)
What light setup do you have? mrSun and Sky with a portal light in the window?
Not necessarily, the rule of thumb is the Max trace depth should be the sum of reflections and refractions.
There will be a big difference in the image between 5 and 30, 30 being much brighter and light getting into the deep recesses, although more contrast will be needed in exposure control.
150 - 200 might be fine, and 2500 too high, I fined around 800 - 1500 really adds detail and subtlety to the light, also cleans up a lot of artifacts.
jhv
may I suggest
FG
Photons
Trace Depth 30
Turn Gamma ON
Maybe some fill light. Off-camera in the hallway behind the opening on the left, behind the camera on the right...
getting there, those chairs seem quite large though.
it feels a bit empty and could do with a little more vibrance and contrast
other than that the settings are ok
i wouldn't have this any higher than 150-200
no point in having this at 30 if you dont also put your max. reflections to 30 aswell.
jhv
ok will do the test result. Thanks
This is standard practice, when the ambient light you put more furniture.
ok, Justin greetings and thank you for responding, with the rebounds are right, already down to 0,
this space is now a thing Sentra does not have a lot of light because the photons that do not fall, so the values are so high The scene has a
daylight mr sun & mr sky and Skylight portal in the window with a value of 0.10.
now I need to know how can illuminate the scene but because the entries are very few lights.
Thanks for all and greattings!!!!!!!
Why did you set the value to 0.1? leave it a 1
Make sure the suns, Photon target is set to be slightly bigger than the window. This will focus the photons into the room. Also means you wont need as many photons.
Also check that the portal light is set to emit photons and leave it at automatic.
These alone should be enough to light the room. If however you would like additional light then I'd suggest a photometric light in the back room. Also set to emit photons, you may have to play with the energy values to see the effect.
Also remeamber to play with the exposure control to brighten up the image. Setting Gamma will also help.
jhv
Edited by Justin Hunt
jhv
Thanks for your explanation, I will prove what I am explaining these and upload the correction
Ps: mr skylight portal: 0.10
Edited by CarlBat
