jccloutier Posted November 17, 2008 Share Posted November 17, 2008 when i try to convert an editable spline to an editable mesh the splines disappear, yet the vertices are still there in the sub-selection. any ideas on how to get it to an editable mesh? Link to comment Share on other sites More sharing options...
rmccoy Posted November 17, 2008 Share Posted November 17, 2008 if it is a closed spline you could try extruding it 0" and then converting it to an editable mesh Link to comment Share on other sites More sharing options...
bijoy Posted November 17, 2008 Share Posted November 17, 2008 yea i think maybe one of ure vertices are not welded together properly...u need a close spline to turn it into a visible mesh. Link to comment Share on other sites More sharing options...
Jennifer Posted November 17, 2008 Share Posted November 17, 2008 If it is an open spline you are looking at, then use the Renderable options of the spline and then convert. Otherwise, adding any modifier to a closed spline will make it a mesh, such as the UVW Map modifier. Link to comment Share on other sites More sharing options...
jccloutier Posted November 18, 2008 Author Share Posted November 18, 2008 you all helped! i extruded the splines to 0" then collapsed the stack now i'm the proud owner of a shiny new mesh. thanks y'all Link to comment Share on other sites More sharing options...
