  • Replies 165
  • Created
  • Last Reply
Top Posters In This Topic
Quick question,
I don't know the structure of the i7, but when I run a rendering on a i7 940 using 3dsdesign2009, 8 buckets was rendering. Also, I check the performance tab in the window task manager, it is showing 8 cores. Is an i7 running on 8 cores? So a dual i7 would be similar to 16 cores?
Out of the box (at stock speeds) the i7 940 is unbeatable as far as bang-buck ratio.
If you plan to overclock, then obviously its all about how far you want to push things and what type of risk you are willing to accept.
yep - With "Hyperthreading" enabled, dual-quad Nehalem systems coming out in Q1 of 2009 will show up as 16 cores to the OS and apps.
*However* - The additional "HT" cores only provide about 20-30% additional performance. These extras cores are still only "virtual".
Thanks, the 8 buckets still feels nice.
I have never used an overclocked PC. I would like to ask forum users if you would recommend an overclocked i7 920 as a workstation PC doing mostly rendering, revit and photoshop at 12+ hours a day? Most of the reviews mention that i7 920's can be easily overclocked to something around 4 ghz with air cooling ( a good CPU cooler, appropriate RAM and motherboard, a good PSU and case...) The performance that will be gained seems to be very nice with respect to extra money given to better components for proper cooling.
I wish you all the luck with OC, but I quit it and would never do that anymore!
I know that Boxx uses an over clocked CPU in their special edition PC, it's not an i7 but if they can do it successfully there's no reason the i7 can't be.
We have spent TONS of resources on engineering these OC'd systems so that they are 100% stable and reliable for working artists and designers -we understand that you can't afford to be "down" due to a wonky workstation.
Overclocking is definitely a "black art" and requires a fairly substantial understanding of how all the components in a computer (need to) work together. Tuning and balancing the system components and settings at higher-than-stock speeds can be maddeningly frustrating.
On the other hand, when it's done correctly, overclocking is a great way to increase your applications' performance.
Thanks for all of the replies to my question regarding workstation overclocking. I have one more question regarding the amount of RAM. i7 CPU requires DDR3 memories and supports 3 channel. So the optimised memory kits come as 3GB (3x1), 6GB (3x2) or 12GB (6x2). Regarding that 8GB is one of the mostly used in performance based graphic PC builds up to now, which would you prefer for the i7's, 6GB (something less) or 12GB (something more)? Using both 3d MAX and Revit at the same time (and sometimes photoshop) will be a common situation for me.
does anyone have any links to timetable speculations on the 6 or 8 core i7's? I do need to build a second machine sooner than later, but am willing to wait for 6's or 8's without going full xeon. Unless of course they're not coming out for another 6 months and/or too expensive.
Where did you see that and why would it be a good idea? Skulltrail for Core 2 Quad requires an LGA771 version of an Extreme series chip, which is way too expensive (over $1500 each), a motherboard that's way too expensive ($600) and requires the expensive (nearly $50/GB) FBDIMM memory and an EATX case, so you have all the constraints of a dual Xeon system, but more expensive, and the only benefits are overclockability and SLI, neither of which are popular in businesses.
The "dual desktop chips" thing is a bit of a misconception, since the only real benefit of the desktop chips over the server chips is price, and in this case the "desktop" chip loses. So unless they make a major change in the next version there's not going to be much of a case for it.
Because Crysis would ROCK during the lunch hour perhaps?? Otherwise, well, no idea??!! :(
WAIT for the next-gen XEON's if it's about work, otherwise buy up now if you're all about lunch-breaks. :)
Those teenagers are not gonna spend $5000 to play Crysis.
