Think i7 Skulltrail boards are also due out soonish. 2 CPU system with desktop CPUs! Sweet :)
I'm not sure where you're getting your data, but I have pretty early access to confidential intel roadmaps - and I don't remember ever seeing anything like a "skulltrail" platform for i7 or Nehalem.
I wouldn't hold my breath for anything like that.
  • Replies 165
  • Created
  • Last Reply
Top Posters In This Topic
Anyway I don't think there are a lot of games that will benefit from 8 cores. What you'd want is an i7 with a good motherboard that lets you do some overclock, and a couple of high end Geforce cards. Still not cheap, but you'll optimize your frag rate.
Currently have:
intel core 2 extreme qx6700 quad core
evga nforce 680i sli motherboard
nvidia quadro fx4600
8gb crucial memory
To increase rendering speed.......
Should one go with an i7? If so which one? I see 3 choices at different price points: 920 @ $295, 940 @ $570 & 965 @ $1020. Is the extra $$ worth the difference in performance?
Newegg has a combo specials with the the i7 and different motherboards. I would have no idea which motherboard to get. They have a:
1) supermicro mbd-x85ax-o LGA Intel x58 atx server motherboard
2) ecs x588-a lga 1366 Intel x58 atx intel motherboard
3) supermicro mbd-c7x58-o lga 1366 intel x8 atx intel motherboard
4) evga 132-bl-e758-a1 lga 1366 intel x58 atx intel motherboard.
5) Biostar Tpowerx58 lga 1366 intel x58 atx intel motherboard
Whats the difference??
What other add-on's are needed if one were to get an i7?
memory? ddr3?
graphics card?
anything?
I would like to order everything I need at once so I can just pull the machine apart and install.
I'll share a little of my research -
At the retail prices and stock speeds, The i7 940 offers the best floating point-per-dollar of any CPU on the market. And better than the i7 920 or 965.
Floating point performance is tightly correlated to raytrace rendering performance.
Take this information for what it's worth.
"Word"... The best you can do for render times is increase your CPU clock-rate (faster CPU). If that is financially viable, do so. If not, don't.
It's as simple as that. Nothing more. Realistically, it you do your maths with CPU/ RAM, a "new computer" will turn up to be either the "best value available" or "a waste of money". There is no magiclal formulae or "what if I do this" scenario, it's just a matter of economics. More bang for more buck. Research, people, RESEARCH!
Edited by shaneis
You don't need a "server" motherboard. Aside from that, look at the included features and figure which you're likely to use, but at this point all the 1366 boards look very similar. I'd probably do the Asus P6T if it were me because I've had a string of good luck with Asus.
The memory does need to be DDR3 and should be in sets of 3. 3x2GB with a 64-bit OS is popular these days, the next obvious step up being 6x2GB. This stuff is currently more expensive than the DDR2.
You can use the same PCIE video cards and the same ATX cases and power supplies. Going to i7 will not increase your power/heat spec.
Daniel, how much does your budget allow? That's the governing factor. If you can factor-in an amount that allows you to O'Clock - do it. If however, you cannot, then go for the most powerful CPU available. That's what I meant.
Sorry if I was mis-interpereteed.
S.
My budget would be around 1K for all parts needed. And I would want a minimum of 8GB memory, which is what I currently have.
I was reading an article that discussed the asus P6T and an included "overclocking" utility in the Bios that seemed to make overclocking fairly simple. They managed a stable 3.99GHz out of a 920 using the Auto Overclocking utility. I have no idea how to overclock so i would love some "auto" feature.
ps...i have vista 64
Edited by danb4026
add
I just went out and bought an i7 920, asus P6T deluxe board, 16gb corsair mem and a new cooling fan.
I am about to install and will let you know how it goes.
I just rendered an image pre-new items, which took 10m 17.1s.
Once I am finished I will re-render and see if there is a difference.
  • 1 month later...
